Cool, I'm glad you can use the mini mixer, it'll be tagging along with your greeblies then :thumbsup
Looking forward to recieving the toggles. The resin for those arrived this morning, I hope you need a lot of them :lol
I'm sure you mentioned they were all the same size in your email. I can hold on to some of the black if you wanted bigger/smaller ones made later or something. Or just use all of it now and get more if you decide to go that way, I'll leave that one to you ;)
UPDATES!!!
Started the long process of moddy'ing the yokes
Before
After
Temp on the console
White primer added - giving a more finished look
Man that sucker is big!
More to come!
Nice build am watching with interest! Just had an odd thought; have you considered putting the console on wheels? Might make it easier to move around and work on.....
Hi oota,
I added wheels to the base a while back - it made all the difference in the world. Made it MUCH easier to move :)
And I bet it's getting heavy as well.
OH YES! I haven't actually picked it up with the cannons attached but I can only imagine how painful it's going to be.
I'm going to try to design/create a portable mount so I can start putting everything together. Not sure how... but I'll figure out something LOL
UPDATES! I'll let the pics speak for themselves :)
LOL! How cool is that? Not practical... BUT PRETTY COOL! LOL
Still flushing out how to mount and balance for easy work - like the console
The impressiveness of this build just doubled.... fantastic job mounting the gun!
Thanks much! Check this out!!!! :) No explanations necessary... ENJOY!
I need to really reinforce the PVC - not sure how... I may get some different connectors... I'm also planning to turn the base into the MF Gunner Window - just for show. :)
THATS IT! I'M DONE... TOO HOT!
Phenomenal work mate. Your speed puts me to shame. This thread has been a real inspiration to subscribe to.
Maybe steel plumbing pipes instead of PVC for the mounts??????
You could pour quick cement into the bottom half of the assembled stand. It'll make it more bottom-heavy and add rigidity (it's the same thing you do when you install a basketball hoop on a stand). Course, it will make the stand pretty heavy -better add wheels ;)
Hi D,
Before I purchased the PVC I was looking at steel piping. And while this makes ALL the sense in the world... it was too expensive and VERY heavy - especially given the thickness "required" to achieve the proper look.
I then thought about putting the steel pipe inside the PVC but that would more than double my costs...
So, I guess I need to find an equal balance. And this is just for display purposes so I don't really need to go ALL out.
Thanks for the advice! :)
Hi KC,
I have wheels waiting to be installed on the bottom of the wood support I created. :) The cement idea is a really good one except for weight. I could try lining the insides of the pipes with fiberglass but I don't think I could cover every critical point.
I wonder if there's a readily available spray I could use that hardens? But I might consider the cement - hmmmmmm
Anybody?
Hi G
How about pouring in some roto casting resin with some fine sand in it or something?
The resin alone will give it a good bit of extra strength, a bit of waight and sets in about 3 minutes.
CONSOLE UPDATES!
Finally cut the hole for the button panel
Cut the starter hole
Then taped off everything to include saw base so I wouldnt scratch the panel surface
A little more trimming up... this part took the longest
Presto!
Now... someone come over and wire it up! I have beer and cookies? :)
I added a bulkier elbow pipe, which looks better, but the fitting is too WAY loose. I can't position the quad into its final resting place without it "see saw"ing.
Bulkier Elbow
It sat in the position for only a minute before I caught it in time! Imagine how much more weight will be added with the back panels and the 4 cannons?
I'm going to cut the vertical PVC pipes almost in half to reduce height and help give a little more strength to the overall support
I'll have to think this one through... Once it's finished I'll add the traditional greeblies, small pipes, and wires, etc... :)
Hi G
Hey C,
I've never even heard of "Roto Casting Resin". I'll look it up!
