I was able to last a little longer today...
The quad bax boxes are almost finished. The high humidity is creating a longer dry time...
I have more images to show but Photobucket is having problems. I'll post soon!
Updated front greeblie... Not sure about the blue pin stripe...
CONSOLE UPDATE!!! WELL ITS ABOUT TIME!!! Permanently mounted the "panel light" / door stoppers to the console! Not sure what I was waiting for or what I was thinking?
Measured out and tapped for drill
Began the process of mounting each light
And now... the beauty shots! :)
More to come!
Fantastic! Awesome seeing the progress you're making.
Do you ever feel yourself start 'rushing' to get something done? Or are you managing to keep a cool head and take it easy?
Two of the best builds i've ever seen!!! Every time i come to this thread, it makes me grin from ear to ear!
Rich
Hi O,
YES!!!! I do find myself, from time to time, rushing a project because I want so badly to see it mocked up or completed. It can be frustrating at times, but the paint, filler and glue keep me in check. You can't rush those items...
In all, I keep cool and I take comfort knowing there is no time frame at all. Most importantly, I'm having so much fun building these projects. Takes the mind off reality for a while. :)
UPDATE / HINT
Spent the morning driving around town looking for items... And I found these... I'm not going to tell you what they're for just yet but be rest assured they are not a towel bar for the MF bathroom! :)
I think you guys are going to be SO thrilled when you see this come together!
SIT TIGHT!!!!
UPDATES
I've sanded all the PVC parts and now I'm starting assembly
Sanded and with a coat of plastic primer
I taped the bottom of the 2-1 reducer and then filled with fiberglass resin to harden - you'll see why! :)
Got the quad back boxes filled and primed. More sanding on the way.
Stay Tuned!
Quad Back Boxes nearing completion
Painting thingy almost ready to go...
Stay Tuned!
CORRECT! I'm now working on the yokes!!!!
After careful consideration I changed the design to include a 22.5 degree angle elbow pipe - When I first started I didn't take the angle of the panels into consideration. This new elbow pipe actually makes the yokes almost perfectly vertical.
The 2 to 1 inch PVC reducer looked good but it was too wide at the base
Priming the yokes
Adding paint
As you can see, the 22.5 degree elbow makes a huge difference - a bit small, I agree, but I'll dress it up.
Front view
Beauty Shot - the new elbow also fits perfectly within the panel pin stripes. I'll also have to add resin to the inside of the elbow pipe (as I did for the previous PVC piece). Once the fiberglass resin hardens I can attach the entire yoke to the instrument console from underneath using screws.
I still have an incredible amount of modding to do on the yokes themselves... But I'm up for it!
Stay Tuned!
