i've only just discovered this thread, and it's possible the greatest project i've ever seen!! looking forward to keeping up with it. Masterful work!
Hi Joe,
Welcome to the RPF! Thank you so much for the kind words. A lot of folks have spent a lot time and energy toward making this become a reality. I couldn't have done it without them! I hope you stay tuned - lots of good stuff on the way!
Thanks again! :)
Hi Gang,
Another quick morning update...
Finally finished painting all of these magnets for the panel lights. Sanded
1 coat
I'm still debating whether to add a second coat. In my experience, the more coats of this paint that is applied you have a 50/50 shot at ruining the finish
This guy will be back lit as well
More to follow so stay tuned!
Hi Gang,
Early morning update! I was all over the map last night working a little here, a little there...
Started off with one of the two door frames - adding lots of filler
While the filler dried I prepped the door for it's 3.5" addition - I laser cut 4 new door pieces. I'll remove some of the original trim and cover piece and overlay on top of the existing frame. This should minimize any unevenness - I hope!
Cut and removed the trim
Sanded
Here you can see how much door I need to add - I now need to remove some of the main panel itself
I then weathered this nose panel greeblie
I then turned my attention to the new "auto pilot clutch"
I adhered the arm to the base
Added a final layer of primer
After that dried I added flat black
Making sure everything still fits
Hi, Winky!
When I pulled the old greeblie off I removed some paint - touch up work here
Against EVERY fiber of me being... I added another layer of the translucent paint to the panel lenses... UGH I KNEW IT! It appears to be another fail. I'll and see how they are this afternoon
The blue one turned out really nice
Previous ones I had painted are now adhered and in place on this piece of wall art
I finally weathered the armrest levers. I'm really liking / enjoying how these turned out. Despite being a bit small there are SO MANY things to do - before weathering
After - first pass
Before
After
Side by side comparo
And done
Big push this weekend! Lots of greeblies, door frame, console, etc
Stay Tuned!
EDIT: OK so curiosity got the better of me!
They didn't turn out as bad as I thought but they're DEF not as smooth as they should be. Next - ONE coat of paint only!
Tiny little bumps
UGH... Need to order more magnets
Hi Gang,
UPDATE! This is not your usual update. As many of may know fellow RPFer IzzyMel has been putting together his 1/6th version of the Falcon cockpit. We'll he and I have been working behind the scenes and we've finally got something to show!
I've been taking my greeblie files and mod'ing them to successfully cut on the laser cutter at 1/6th scale. After a few failed attempts I was FINALLY able to knock a bunch of greeblies. Just to give you an idea of how small these greeblies are - the entire footprint on the cut was 5" x 12"! Enjoy!
Standard Dry Erase Marker for scale
I brought them home, cleaned them up and got them ready for some primer!
I adhered the multi-layered greeblies together
Some required a little more work. I broke out the lighter and carefully bent the parts to shape
Primer! Several of them need some light surface sanding to knock down the small lip created by the laser cutter. On some it looks the part
We're also working on decals of the cockpit - so the vertical gauges might be back lit. I'll leave that to Iz!
The dreaded mystery greeblie and the 4 little greeblies that go around radar scope
A teeny tiny Garrard trim piece
How teeny tiny?
Yup... even the I Bolts!
Dont Sneeze!
A little sanding
Hey Iz! Enjoy - they are on their way! OK... I gotta get back to work!
To see his build - click the link below! :)
http://www.therpf.com/showthread.php?t=241516&highlight=1/6th+Scale+Cockpit
More to Follow!
EDIT: I forgot to add this pic of the 1/6th clutch next to the 1:1 scale version :)
Great update as usual Sofa...I showed the your pics to the GF and ask the following question: who's crazier; me building the 2001 Space Station, or this guy here, building the MF cockpit 1:1 scale? You get the mention "Crazy" Sofa:D...but, as far as I'm concerned, you're the coolest one!
Hi Gang,
Quick Morning Update! As you already know I did a lot of work on the 1/6th Scale cockpit over the weekend but I was able to knock out a few things for the 1:1 scale as well. :)
The weekend started out with the laser cutter. While that was going on Jessie and I got the second door frame finished up
Still lots of sanding and priming to do - plus I have to figure out how it will all go together
I then worked on the auto pilot clutch. I'm really happy with how this is turning out. It's about 95% finished
I cut a new top piece. I want to add real screws to the top so I drilled holes - painted black
Gold
Slowly coming together. I def need to spray some satin clear and bring down that high gloss
I decided to cut a new center piece - painted black
And the two silver pieces that sandwich together
Black
Silver
This is how it looks right now... Unfortunately, the bolts are a bit to high and wont fit around the arm
Top with bolts
I'll figure it out
Jumping back to all the laser cutting... we had a few errors. Note the LONG horizontal line that shoots off to the left - not good!
ugh...
I cut a new "cup" greeblie for the canopy boxes
I cut and applied these two new greeblies
This guy is almost finished
I am so excited to announce... I designed another of these panels! #5!
I hate this thing
FINALLY!
There are 6 rockers on this panel - 3 inside the panel greeblie and 3 in various places.
I cut this mounting template for the armrest levers
I cut these with the idea that they would be the LED housing for the instrument panel LEDs
I laser cut another template that allowed me to cut all the mounting and LED holes in the instrument panel
I removed the cradle and realized we had a slight problem... The instrument panel was not CNCd to accept most of the LEDs. This was an oversight but nothing that can't be fixed. This entire area sits within the center console and we have lots of room to play
Good area
The LED wires will have to be fed up through the entire instrument panel - what you're looking is the actual bottom of the exterior
No to be discouraged I moved forward. The LED panel in its final spot
This is how it will look when lit and with the smoked acrylic cover
Its interesting how the smoked acrylic makes the white acrylic buttons appear blue - going to look so cool when it's all wired
Finally, I cut these mystery pieces
I'm not saying what this is just yet. Some of you may see it. ;)
Routed the base
And added lots of filler
I didn't get around to finishing the door... that will be this week.
There's more to come, so stay tuned!
LOL! I'll take that mention! :) And thanks for the kind words - as always. Speaking of 01 SS - how's she coming along?
Whenever i need greeblie inspiration my friend, all i have to do is drop by here for a look. Just unreal!
Thank you, my friend! As much as I love this project I wish I had the freedom you have with your build! I would love to be able to do what you're doing and just have fun with it. Dont get me wrong, I'm having a blast, but I'm so restricted to making everything screen accurate.
The things we do for our craft, right? ;)
Oh gimme a break... I've seen you divert from the accuracy many many times... you just don't think we notice but I got my eyes on you bub!! LOL:)
Hi Gang,
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_114042_zpsovsopneo.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_113138_zpsavl003bu.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_142819_zpsdpv5fftg.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_142825_zpsjs04iceb.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_142834_zps1niwnwma.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_142838_zpstltkwkrv.jpg
http://i778.photobucket.com/albums/...it/2015/Oct/20151025_143829-1_zpsuegjgjqh.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_142850_zps5wliyn5w.jpg
http://i778.photobucket.com/albums/...it/2015/Oct/20151025_142920-1_zpst0cregbz.jpg
http://i778.photobucket.com/albums/...it/2015/Oct/20151025_143300-1_zpslleiekjl.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_143452_zpsrepaaba4.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_143457_zpsqqktih8i.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_143834_zps7y1yuxcs.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144855_zpsbe7x41ey.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144908_zpsvmsiaszq.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144912_zpsle6vjizc.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144916_zpsyjybyzyv.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144921_zps0uttivde.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144928_zpsvsvl0zwd.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_144940_zpsrszwdvlg.jpg
How teeny tiny?
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154058_zpstgfkebix.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154210_zpsgiifac6c.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154222_zpshf8bunro.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154230_zps8pc7sgoo.jpg
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154705_zpspqtwqa6q.jpg
Dont Sneeze!
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154720_zpso9od32bg.jpg
A little sanding
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154744_zpsv1uf5ho6.jpg
More to Follow!
http://i778.photobucket.com/albums/...kpit/2015/Oct/20151025_154338_zpsshvvhewv.jpg
Thanks SofaKing0. Can't wait. Looking forward to getting the parts.:D:D:D
