Grenade question...
My stem is majorly stuck in the frag body. I can't budge it a mm. I tried soaking that connection overnight in coke. No change. I've had wd-40 on it about 5 hours now...still no give.
Anything else I can do or is it perma-stuck?
If it's stuck - i'm thinking getting a bolt in the head to attach to the emitter is going to be less than fun.
Even though it's 1918 ish - i assum CCW is tighten, CW is loosen? yes? I have tried both directions to no avail.
I had this problem.
I broke my pin off the neck trying to get it off... so BE CAREFUL.
Here's what I ended up doing... (assuming I'm understanding correctly what your sitch is)
I soaked it in deep creep (I believe that's what it's called) it's a spray for rusted bolts.
I had it in a clamp, and used rubber, a small screwdriver and a wrench.... leverage did it all. finally moved.
Did this TWICE (when I got a different neck off of Edraven)
Here's a link to pics of my setup:
http://www.therpf.com/showthread.php?t=225882&page=7
post 172
