That is sweeeeeeeeeeeeeeeeeeeet.
I've got a 4k version if you want it
SB
SB
In theory, yes, you could putty the gap or something similar. But the way that Bandai have engineered this kit is that they made the cake section removable to access the switch for the lighting, which I just went along with. I have an IR remote powering the engines, but the main LED strip is still accessed by removing the cake section. I'm still trying to think of a workaround there.
SB
Those images are sweet, what software did you use to make them? That would be a lot of fun to try.
Look what I found on page 2, waiting for a build update!
Am I right in thinking that some of the studio models had T shape engine struts and some had a triangle profile?
I was planning to use 3mm brass 90degree angles, and making them into triangles by adding styrene to cover the open side.
For the pipes I think I worked out that they would be roughly 1.5mm, based on scaling up the .stl files (so assuming the stl files are correct). I bought brass rod as I think it will be easier to work with than styrene.
Very cool picture!
Also congrats on the Spitfire in Fine Scale Modeler Reader Gallery
Wait, what?I completely forgot about that! I accidentally let my subscription lapse, would you mind posting a picture of that page?
SB
oh well done Steven! Very well deserved
I also like your SD pictures. Maybe I could persuade you into doing something like that for mine when its done?![]()
