Djstorm100
I've been searching to to see when you guys use Rondo. When to use it/how to use it etc. From what I gather it is to make the inside surface smooth and not run the risk of having sharp points like you get with fiberglass sometimes. But do you use the Rondo as the agent to hold the fibgerglass down? I normally spray adhesvie and try to use large section of fiberglass cloth to get a uniform look and feel. I would basically "glue" the fiberglass down and then pour the rondo in there and spread it around with my hand? I image you can only do small sections at a time when working with objects like COD since it is full of curves. Was thinking about trying it on a peice for giggles and experiment.
