Thanks for posting the comparison shots.
I will machine a smaller ring tonight and throw it on my RussRep Sonic. I will post a pic and see what it looks like. I think Russ's sonic is really close.
Did you get round to doing this phez?
Yes, well I machined it out of a piece of copper plumbing tube I had laying around :lol but you can see the size scale of the parts. I am fairly sure Russ's sonic is dead on with the smaller halo. The bullet looks correct to me so I think it is possible that the 1/2 inch magnet is likely what was used on the origenal.
NOTE: The 3/4 magnet is WAY too big (it is the size of the whole halo in my pics).
I think the magnet should be a tad longer though for SA.
I think you are right. But looking at the screen caps I think you might ba able to see a line where there might be a small shim between the magnet and the bullet. I am trying to get some good screen caps of it.
With a smaller halo, longer magnet, slightly narrower grooves on the slider and a smaller additional one on the base, I think that it would be the most accurate version to date.
Agreed, with the addition of the rounded convex bottom as seen in these screen captures:
Pic credit: phase pistol
Pic credit: unknown
What is the deal with the handle on that Pertwee Sonic. It looks like there is some kind of grip on it. There is black under where the hand is holding it and it looks like a red strip at the top of the handle ?????
I have also noticed that from this screen cap the bullet is not flush with the emitter ring..it extends a hair past it, I am not sure if anyone has mentioned that before in this thread?
It has been mentioned, but more interestingly with that bit of info, you can tell that the halo was very very small in diameter to be able to disappear that far down the end. Something I hadn't thought about till you brought it up again.
I figured it had, as we have quiet a few sharp eyes herebut good call on the emitter ring as well. yes I does sit fairly deep into the shaft. That being said..could it be that the ring size changed as later on it didn't sit as far down in. Or did it remain the same and just the set point of the shaft changed
