Supernatural EMF detector
My version of code and circuit schematic.
This will read EMF from an antenna, display on the LED bargraph, and play sound when a preset threshold is reached. In addition, there is an override button to force the sound and animation to trigger.
Not coded yet:
  • Analog Meter output
  • Threshold selection by potentiometer
  • Mode selection (demo/prop mode)
Arduino Code:
https://codebender.cc/sketch:28269
Circuit:
Demo Video:
Not coded yet:
Arduino Code:
Circuit:
[url]http://farm8.staticflickr.com/7290/12094754483_c44303bf6b_m.jpg[/url]
Very cool! Great job.
I still need to keep playing with that sound, is a basic approximation right now. I think I can get closer by mixing multiple frequencies to the speaker. Data I am using to generate the sound is below.
EMF Sound Sample (2 seconds):
Mediafire - emf_sample.wav
EMF Sound Sample - Spectrogram Analysis:
If you look closely, you can see the highest high tone in the center. A heavy 1000hz with a light 2000hz mixed in.
That plan sucked, lol. Instead, I went with a PCM audio library, converted the audio, and stored the entire shortened clip in arduino memory.
Normally PCM playback is dependent on an SD card to store the large .wav file data, but a small tweak and you can store the .wav file locally (without an SD card). You just have to keep the data small, under 4 seconds small.
Brief demo of the audio: https://www.youtube.com/watch?v=mEpeiSOC9lc
Next step is splitting up that short clip further into sections. Looping the different sections to be longer, etc.
I'm about ready to dive headfirst into this, but it seems the parts list from FriedGeek is completely gone. Thanks to the work of many others in this thread I know I can get the LEDs, some of the switches and potentiometers, the Syntax board and a Draper multimeter to begin with, but I'm wondering if more complete parts lists and Arduino circuit diagrams are available, or being played close to the vest. I suppose I can pore through electronics catalogs if that's what it comes down to.
I'd dearly love to make one of these, especially with thedecade's recent work with the squawk sound. Sure, I could buy one, but I want the challenge and learning experience of assembling and programming one.
I too am working on an updated standard part list. Currently, I am still missing:
  • the square resistors (top)
  • antenna holder clips
Some progress I have made. Designed a custom pcb to make the additional arduino circuit better hidden. Leaving the work area untouched so that you have to run wires to the knobs and switches, still giving the emf reader that hand made look.
You may notice that some of the square pads are missing a hole. Those are fake vias to hide the backside circuit. The mockup doesn't show the solder mask layer very well. I assure you that each shiny square will have a dark spot in the center.
Overview of the parts I have found so far. Still missing those box looking resistors located under the LEDs.
Specific Part List
Use these exact parts for accurate 'do dads'
Generic Part List
These are the parts I am using, use what you can find local and cheap
Powered Part List
These are additional parts to make the 'do dads' light up and do things.
  • Battery Clip
  • Resistors
  • Arduino
  • Mini Audio Amp
  • Mini Speaker
http://farm3.staticflickr.com/2839/12234930653_51913c3c16_o.png http://farm6.staticflickr.com/5497/12234930083_79597d887d_o.png
I think i might have some extra left over from when i did mine if you still need them ;)
By this, may I infer that you want to split the short WAV into three parts? And if I may illustrate with onomatopoeia, I see it as "erREEEEErr". Perhaps split the clips into "eeR" "EEEE" and "Err", and loop the middle "EEEE" for longer sections?
Correct. The EEEE and eeee sounds are the trickiest as they must be looped for the high and low readings. The looped sounds get a little glitchy on the transitions.
I have the looped audio written up in code, but didn't take a video because I didn't like the way it sounded with the looping. Still needs some re-work.
Great work guys! I'd be interested in purchasing one if anyone plans to make additional ones once the prototypes are done!
Hey guys! Is anyone still making any of these for people who want to buy one? Just thought i'd check coz it's a pretty old ongoing thread now!
