Hi Ged,Loving this Snowspeeder build too Mark ! . If you don’t mind me asking, how heavy will this end up being, and are you planning to light her up ?
Oh, and the colour you’ve painted the ‘ exposed ‘ underlying framework - is fantastic too !..., it kinda reminds me of some of the exposed pipe work (colour) around the entrance (where the rebels flew in) of the 2nd Death Star in ROTJ .
Ged
Thank you! At the outside I have used four lego cylinders, two at each side in the front directly beside the two pipes. The rest is styrene which I cut myself. Inside the back engines which are closed on the picture above I have also used some lego parts.Beautiful. Do I see some lego greebles in there?
Thank a lot!That's amazing. Great job!
It looks fantastic! I also use legos. They blend in great and have that crisp machined look. Amazing paint work too!Thank you! At the outside I have used four lego cylinders, two at each side in the front directly beside the two pipes. The rest is styrene which I cut myself. Inside the back engines which are closed on the picture above I have also used some lego parts.
Best,
Mark
Thanks a lot, very friendly of you! Legos can help sometimes.It looks fantastic! I also use legos. They blend in great and have that crisp machined look. Amazing paint work too!
Hi Ged,G’day Mark , with regards to ‘heavy’ , I was referring to the actual weight of the model( due to it’s size & seeing you holding it up one handed ).
Your paint & weathering is superb !.
As for ‘lighting’ , that’s totally your decision of course - it’ll still end up looking fantastic either way , but just a few scattered around the interior - especially for the computer screens would be cool too !
Those pics of the ‘speeders’ flying side by side in formation is..., wicked !
Ged
Thank you Jake!They look perfect together. Like a still from ESB!
Thanks a lot Joberg!Fantastic build and the pics are unbelievable![]()
