Studio Scale painters, I have a question
Gigatron
Hey gang,
I recently picked up a CC x-wing and I was wondering what kind of paints all you master painters prefer to use and why.
I normally build and paint WWII warbirds using tamiya acrylics. I was wondering if you guys prefer acrylics, enamels and/or particular brands.
FWIW, I use an Iwata Eclipse BCS for large coverage, but my workhorse is an Iwata Revolution BR.
Thanks,
Fred
I use acrylics (Tamiya) primarily because I have good color choices, it mixes well, and cleans up nicely. It doesn't adhere any better than enamels, but it does almost as well with a good primer (I usually use Tamiya gray primers).
Mixture really of acrylics and enamels from Tamiya, Floquil and Pollyscale, depends what i need from the paint i guess!
Cant go wrong with the Tamiya though, it mixes well and has never let me down!
lee
Fred, for an SS X-Wing, I'd suggest the Floquil Railroad color palette, especially the Caboose Red for the stripes. Though color formulas may have changed over the years, the overall Floquil pallete - to me at least - fits the X-Wing look better that the Tamiya pallete, and is what McCune et al. used.
Beyond that, I really like to use Liquitex acrylics (availabe in tubes from art stores). They break down with water, and can be thinned to airbrush. They can also be hand-brushed on. And the greatest thing is that if you **** up, they clean up MUCH easier than Tamiya paints. ust get a wet paper towel and wipe off. After a certain amount of time, Tamiya can be tough to get off, but not Liquitex. You do need to seal it though with a clear coat.
Thanks for the responses everyone :cool.
I may do the majority in tamiya acrylics, but I may look into getting the floquil caboose red for the red stripes (thanks for the tip, Rob). It does seem to be the defining color of an x-wing.
So here's another question. Do you guys seal the paint afterwards and if so, with what? I usually use Future, but I sometimes have a problem getting a smooth finish. Is there something better that you guys prefer?
And what about weathering techniques? I'm good with salt chipping and shading with an airbrush, but are there any inside secrets?
Sorry for all the questions and thanks for any replies.
-Fred
I'm big on sealing with a clear coat, but -- especially with the SS X-Wing -- you'll get varying responses. The original finishes were accomplished with a steel wool rub down which offers a unique (and familiar!) sheen. But I personally use a lot of pastels, so pretty much have to seal my weathering. I use Testor's Flat (or Dullcoat) from a rattle can, which goes on super thin and virtually NEVER orange peels (unless its way cold and goes on way heavy). I then buffed the clear coat with steel wool.
Chips and scratches... Lots of aproaches, and mostlikely very similar to the old war birds you work on, Fred. Some here use latex masking, others use the so-called salt technique. Personally, I just brush on the white paint over the top of the main color (like the red stripes). It's easier, gives you much more creative control over the shape of the blemishes (especially if you're stringently following ref pics), and if done properly, you can't tell its painted over the color (opposed to chipped away) unless you have a magnifying glass or are otherwise TOO close to the model.
For applying dirt and grime, I use pastels a LOT. Applied properly, you get the same look as an airbrush, but again have better control (well - I SUCK at airbrushing!). Just make sure the colors are natural. I have a hard time getting natural browns; most of my X-Wing was done with black pastel powder. I do like to thin dirty looking oil-based colors with thinner because I like the way it reacts as the thinner breaks down the paint on the surface of the model, but this is a dangerous technique as the thinner evaporates quickly and can leave a muddy mess, and too much of it can begin to attack the undercoat.
--Rob
