Rocketeer Rocket Pack from found parts
I love Home Depot. Unless I need something fixed around the house and need advice. :lol
For the cones on top, I'd suggest blue painters tape around the steel cones to protect them. Then get several cans of expanding foam. Build a cardboard disc just inside the tubes, squirt the foam inside and let it set up. Once dry, sand down the foam to a basic shape. You can bondo on top of it to smooth it out.
Or just use some insulation foam. That might save you a step. I just don't know how much it costs and the expanding stuff is less than $5 a can, if I remember correctly.
Looking forward to your progress.
For the cones on top, I'd suggest blue painters tape around the steel cones to protect them. Then get several cans of expanding foam and a couple of balloons. Squirt the foam into the balloons and let it set up. Once dry, remove the balloons, sand down the foam to a basic shape. You can bondo on top of it to smooth it out.
Great advice!
I'll offer another possibility. Cut the top 6 inches off a plastic 2 liter soda bottle. Cut the threaded opening off. Add some Sculpy or other modelling build up medium and shape into the cone. Once it's all dry--primer and paint.
Great advice!
That's a good suggestion. There are two builds of rocketpacks online (not on this site) and one.used coke bottles. Another suggestion is crab floats. They are more sturdy and easier to attach items too.
Another suggestion is to scratch build. A member here named hikz I believed made an amazing rocketpack.
I have a couple of rocket pack projects in the works, using mostly found parts. I'm eager to see your progress.
If you get a chance to look, garage sales and thrift stores like Goodwill often have dirt cheap lamps with conical sections made of hollow brass or steel. The parts nest together around a threaded inner rod. These make very nice conical tips (for aerodynamics) or exhaust nozzles. Also, they can sometimes cost less than the most humble part you can get at a home improvement store. I lucked onto a couple of matching lamps at a Goodwill that yielded enough cones for at least two packs.
Slightly off topic- So Howard Hughes (fictionally) invented the Rocketeer pack. Howard Hughes also (actually) invented the flush rivet.....
Why no flush rivets on the rocket pack?
At most dollar stores you can find 3 liter plastic bottles of soda you can use for the nosecones. I also use modified drinking bottles that look like tiny sparklets bottles for the rocket engines.
Holy cow you guys are awesome!!! Thanks for all the helpful info
Evilrocketeer: Sweet ***** thanks for even looking at a thread of mine you rocketeer God you! A strict budget is a great idea i guess I'll set 200 limit
However If this starts to look really bad I'd deffinitly be interested in saving up and contacting you to cut out the middle man that is MIM. Thanks!
Finhead and mikey123mushukl: Gentlemen as Ron Burgandy said here
I havent seen a rocket pack on this site that I haven't marveled at with amazement!
Prefect42: Thanks! I am definitely looking into that now and am hopefully going to do that!
Pics to come!!! I really hope I get some time tomorrow to work on this because for the next three weeks I have so much prop freaks stuff going on I wont have time to breathe
And thanks to everyone else for looking and for the encouragement!
