Road to ECCC: For Super Earth! Three Helldivers from Helldivers 2
BackYardProps
Hello everyone! BackYardProps is back from the dead to give his life for Super Earth.
This costume has been a long going project since October of 2024, and I have been working on it to this day and even as I type this.
I decided to make a thread to post my journey so that one day you too, can do your part and spread Managed Democracy.
Let’s start from the beginning…
…so let’s begin. I have not been to a con or cosplayed since about 2018-2019, and I have missed it so. So finally this game called Helldivers 2 comes out and I am finally able to play it, and BOOM. Here we go.
I purchased all of my files from Aaron over at Galactic Armory.
Away we went with printing…
Printing on an Artillery Sidewinder X2, I left the files as is and did not size or scale anything. I Assumed that Aaron and I were roughly the same build. Thankfully I was right. So we printed everything, and ordered about 12 spools of PLA with 5% infill on parts.
I was able to “hire” a buddy of mine to borrow his Bambu X1C to print one as well. All together I had to start printing 3 costumes. And about 2 months worth of JUST printing alone.
From past experience I learned that I absolutely HATE bondo… so I followed GA’s guidelines and tried using UV Resin to fill lines instead.
I sanded the armor first, and then brushing it on lightly, hit it with UV, wash rinse repeat.
Once the pieces were cured I would hit them with a combination of mouse sanders, disc sanders and hand sanding, hit with filler primer, wash rinse repeat until I thought the surface was smooth enough. I would do this before wet sanding.
As you will see in the photos there is a LOT of sanding that I needed to do. Ended up needing to use some bondo in some spots.
There was incredible amounts of sanding needing to be done. And as the pieces popped off of the printers I would add them to the piles and things to sand.
I sanded with about 120-180 grit sandpaper and then finished it off with 220 and a rinse of water to get all of the insane amounts of dust off. Once everything was hit with filler primer it was nice to see everything start to have a uniform color.
It’s important to note, Some pieces needed to be sliced in half on the program, so I would super glue them and use a soldering iron/spare PLA to mend the halves.
One of the armor sets was for my girlfriend who has a smaller build than the two other costumes, so I just guessed on scaling it down and thankfully it was right. Everything just needed to be scaled down on the X axis (skinnier) as everything else was good, we are all tall people lol.
Let’s see some more progress!
So what is a Helldiver without their gun? We started printing three guns: The Liberator, Diligence, and Breaker Shotgun.
A cool feature Galactic Armory does with his weapon files is allow them to be assembled through a central wooden dowel, which helped TREMENDOUSLY!
Meanwhile, we started wet sanding with 400 grit sandpaper, which left the pieces unbelievably smooth. If you don’t wet sand, then what are you doing! SWEET LIBERTY, DO IT!! It’s hard to believe these were printed.
We also got some holographic Stratagem Tacpad screens!! The plan was to line them with some sort of LED light on the arms. More on this later as I was still planning how I was going to do it.
After everything was wet sanded I got impatient (or proactive?) and started painting everything black as a base coat. Meanwhile the guns were printing.
  • 467B0675-7DEB-4030-AA6A-685E8A50A37B.mp4
    2.3 MB
We won’t come back to the guns for a minute. by the time the black base coating started it was about mid December, I have until March, but I knew painting would take some time so I began to go into turbo mode.
We started the massive masking party… black was primarily the perimeter of the armor, so we began covering everything we wanted black to spray with gunmetal, and once the gunmetal was painted we would mask off for yellow, and then silver!
Every yellow stripe was based on reference images, I tried my best to use other lines or ridges on the armor to base my drawings and measurements on, but overall I think I did great with matching the armor. Masking alone took 4 rolls of tape for all three costumes. I would take the armor to work and mask on my breaks. Everything looked great in the end but it was TOO CLEAN!! So let’s think about doing some weathering shall we? Weathering is always fun.
We also got some decals made to be applied to the armor.
Blackwash, what else is there to say! I will recommend clear coating the armor BEFORE Black washing. ALSO… try using oil paint and mineral spirits instead of watered down acrylic, it is SO MUCH BETTER.
Visors were ordered through GA and applied to the helmets bringing that all together, and finished with a Satin clear coat.
The tacpad was revisited and the LEDs were installed, turned out great. I wish they were a little brighter but it’ll get the point across.
WE GOT THE CAPES TOO! Hell yeah. Not much to show other than they are there and they are awesome. Galactic armory did a phenomenal job.
The under armor on the forearm and thighs were free handed foam cutouts with waffle fabric sewed on.
  • 277C0ADA-65C9-4100-904F-198B40832164.mov
    8.8 MB
Which leads us to where we currently stand.
The costume is almost complete, with a few odds and ends left! More progress soon.
I ironed on the vinyl to the shirt, some small details left to do. But not much, we are getting close.
Heat applied vinyl from a T-shirt press, applied to the shoulders. 2 down and 4 to go. These are a huge PITA to do. Surprisingly easy to center, hardest part is getting it glued and trimmed.
There’s a few little quirks to fix but besides that all THREE costumes are done!! Minus the guns which I may not get to for con. We went on a walk through the neighborhood and tested the fittings, so some adjustments to be made. More photos soon!
Looks real cool:cool::cool:(y)(y):love::love: Of course, black socks are "de rigueur" with that type of costume. Maybe an extension for the neck cover also (that's just me, Mr. Style:p)
Yeah we all don’t have everything yet. Thanks for the input. We certainly will have proper neck covers n such soon
