Need PR help!!!!
OdiWan72
Hi all
I´m working on a PR right now and ran into a few problems.
I have one of Tommins PR adapters to attach the SPAS cage to the M1A1 and the cage is held by two screws from the inside. Well...when THESE screws are too big and won´t allow me to insert my real deactivated 870 into the cage.
Beside of that I´m in need for some advice what to do with the trigger area of the 870?
Shall I cut down the guard completely (there is a spring in the front section)?
If I´m leaving a bit of the front guard it doesn´t fit into the cage, if I cut it off completely, I´m having problems with this small spring.....ARGH..... :cry
Here´s what I´m using for my buildup.
- TM M1A1
- Tommin PR adapter
- Real Spas cage and pump
- Real deac. 870
- Matts steel vent and stock
- SD´s metal upgrade parts
- Matt´s shroud
- HD electronics
Can anyone please help me and guid4e me through this?
Pics of your own PR, preferred during construction would be highly appreciated.
Thanks, Markus :)
...and how did they get the 870 in the cage?
Anyone who´s got pics of the underside of the cage?
The other problem is that the screws that hold my cage to Tom´s adapter are way too big and the 870 sits pretty much flush to the inside of the spas cage :unsure...no space for any screw(s)
Markus
