So I found a compac scope for my Greedo Killer. However, it is the wrong type of Compac
The only problem is that it is the wrong model scope. It is a 4x31 like the one pictured here.
So I wanted to strip the scope and use parts to make an acucrate copy. Now the bell part on my scope is the same as on the correct one. And I have a set of resin knobs and mount and front tip.
However, I need to replace the straight knurreled section and the main tube itself. So basically I need a plain tube and knurreled ring off of a scope of similar size that I can modify and screw the Compac bell on (I hope some of this makes sense). So what I'm asking fromyou guys is, does anyone know of a relatively cheep scope who's parts might be adaptable to a Compac scope.
Thanks
Dan
DDStoeks@aol.com
Thanks
Dan
DDStoeks@aol.com
