MY SIDKIT BLADE RUNNER BLASTER...
IGNITERS
[attachmentid=12971]Well I picked this up a couple months ago and went to work on it like a posessed lunitic,it's based on the worldcon discovery,what do ya think?
yes ...well,3 weeks of potato chips and soda pop under a 40 watt bulb will do that to a person ....(cant hide the tattoos hahah)
well,you held it so .....you should know ,thank you for the responce.
Looks great. What did you do to get the switch box on the Ammo cartridge? I'm 98% done mine and that's one of the things left.
well, I feel kinda lazy here ,what I did was find a switch at the local electronics supply house and see-mented it to the side (this one doesn't function) and the working one is still on the clip.
Really what I should have done and probably will still do is drill out that area and get a working switch in the propper location .I am no tessla and it was really my first attempt with a soldering iron....
I filled the hole in the bottom of the clip and use a "super magnet " to hold it on as well as installing the 5th bulb,it actually went together quite easily after the sanding polishing and blueing ...MAN THAT THING IS HEAVY.
( oh thats clear amber grips like the original ,probably thrown by the paint and blueing underneath)
Looks really good to me. One thing I noticed when looking at the photo you included in the background...the grip looks longer in the comparison photo than the one on your gun. Is that an optical illusion or do you really have big hands? ;)
Prop looks fantastic. Congratulations. For those who asked about the grips - In my experience, all of the BR blaster repplicas produced to date have had grips that were too short (like half an inch too short, or thereabouts). I believe this is something that was being rectified for the latest RAC model, but previous RAC's, SidKits, Offworld, etc. had grips that were too small. For some reason, the grips on the Hartford blasters seem a little better proportioned, which is odd given that they're based on an RAC.
In any case, the buildup here looks brilliant. Really, really good job. How did you get the SidKits pot metal (pewter?) to take color that well? :eek
Igniters
Looks fantastic man. :eek
I have one of these arm-buster cannons to, but my progress has petered-out due to business distractions.
This fine example of what's possible has rekindled my interest.
Thanks for sharing. let's see more pix please.
One question- What did you use to blue the metal?
Once again- nicely done.
Thanx
Looks excellent.
Like a couple others have asked, what did you use to get that finish on the metal? Paint? Chemicals? Magic replicant dust? :)
Very cool.
In related news, I see that CDNN has bought the entire US domestic stock of Steyr Mannlicher rifles. Anyone know the model receiver used? I know it's a Rem .222 caliber. For those thinking of using the real parts to make one.
Thank you for all the encouraging words....The big question seems to be how I got the finish,well here is an explanation.
After practicing on some tattoo machine frames I was dressing up and talking to an artist that also works with metal sculpture....I have a small process I went through.
- I figured gun metal is probably polished before its final finish due to tolerances and durability so all the parts on the kit that were metal ( everything) I wet sanded to an even smooth finish
- "SUPER BLUE" gun blueing (I am sure most blueing is the same) was applied in stages depending on how dark the end result required,on the cylinder and barrel I applied 2 or 3 coats and wiped wuith a rag between to even the finish and wipe of the rust brown residue left from blueing
- fine finishing or lightining was then done with steel wool ( comes in different coarseness,softer than sos pad) then and this may or may not be a surprise..."BLACK SHOE POLISH"....mmmmmm love that smell .....
the shoe polish gives the metal a rich smooth shine, finish , and seal without staining and helps adhere the blueing to the metal so it doesn't wear off from regular handeling
- for the painted parts I first scuffed them with a soft sandpaper and applied 2 coats of black primer,then a couple coats of "bumper black"(which is satin strait outta the can and a little less brittle than regular paint) then a light coat of clear gloss...
- now for the light rust you have two options,well 3 if one of then is skip it ,but you can either go to micheals craft shop and get the 13 dollar liquid that rusts metal and take your chances with that or just buy some rust brown testors paint and a piece of pot scrubber and add less or more as you wish with dabbing a stipple effect...you can also with a needle or pin score the metal so the paint filles the pinholes like attacking rust (this is what I did ) takes alot of time but looks really cool ...
well thats my secrets for this kit ....it was worth it if you really dig the way it turned out,thank you again .
[attachmentid=13002]here is more photos.....
Awesome, simply awesome... I am not sure if you stated it anywhere, but how long did it take to do?
