vaderdarth
Here are a few shots of my SD build and where she stands. Finally made progress with the buildings but still have a ways to go to get everything to fit right. This has been a tough thing to work thru.
First the finished nose section (I basically re-built this from kit bash parts)
Next is a shot of the bridge and top details including Fiberoptics for the bridge and neck section. As you can see I taped the tractor beam generator into an ANH-esque upright position. I'm planning on hinging it to pose up or down.
Next is more of a side shot of that area as well as more of the buildings and details...
Next is a full shot from the front at an angle showing all the parts
together.
And one more from the other side. My plan is to make the upper hull removeable and attach with tiny wood screws. This way I can get back inside should it need replacement LEDs etc... I also plan to create a metal framework inside so I can support the entire model with a couple camera mounts. I want it to "float" when it's displayed.
together.
