Since most of the other multipass build threads don't have pics anymore i will post up my build. Maybe it will help someone out.
Very nice kit Mr Munson!! Graphics are pretty awesome as is the rest of it.
Here are the parts i received today. (i already trimmed some of the front graphic)
The parts have a protective paper coating on them. In this pic i already started to smooth the LED trim edges.
Here are the parts without the paper coating
To get the LED to sit as low as possible i pretty much mashed the leads over as low as i could get them and trimmed the plastic edges.
Again in an attempt to lower the LED i marked and ground down the back plate as much as i could without going through. A little with the Dremel and a small sanding drum then scraping with an xacto. It's not much but every bit helps.
The result. Not sure i can go any lower and will leave it at that.
Here i glued the front 2 rings together and ran a bead of super glue around the edge. I will go back and sand it all smooth tommorow.
Next i trimmed the corregated parts. Marking then trimming and filing. I did the rear one first so if i screwed up i could hide it if needed. The rear could have been a hair wider but good enough for me.
And a little test dry fit and i'm done for the night.
Tommorow i will figure out a switch/battery setup for it and i need to get some paint. Anyone know what color?
