Logan's Run Flame Pistol Sandman DS gun - 3 separate, 3D printed "working variations"
propmaster2000
During my quest to create a working 3D printed Logan's Run Flame Pistol I did a bit of research
on the net and found that there are many versions of the all metal type and several versions of the painted,
3D printed versions that have LED lights and without, assembled or in kit form available for purchase.
As well as some resin type.
Getting my flame output version to work was my biggest challenge since I had to reconfigure the "flame output manifold"
so many times until I got it the way it was intended.
The actual working flame pistol has a much larger CC and water mixing chamber then my design and could potentially output
a much greater gas output pressure to produce the single torch style flame necessary to give the final look of the 5 flame result.
Since mine is 3D printed in PLA plastic there are certain aspects to consider for the final design.
Having reduced gas pressure, I needed to send the gas output into 5 separate pin hole nozzles directly and then ignited individually.
By doing this, there was no way to design in a venturi gas/air mixing section to reduce the black smoke and produce a hotter flame.
Getting 5 separate ignition sparks to work at the same time with the proper intensity was a huge hurdle to overcome.
I only had limited space available in the grip for electronics and sufficient battery power to get a good spark at each nozzle.
As far as I know, it is the only 3D printed plastic, working "5 flame output" Logan's Run Sandman pistol so far.
Of course, I couldn't resist coming up with 2 more variations on a theme as seen in the video. :)
Below is what I managed to create during my design and build (print) process.
I used my ENDER 3 printers and a simple CAD rendering program to create these interpretations.
Thanks for watching :)
OMG !! Those are AWESOME !!! The internals are brilliant !! Good Show. Iconic pistol. Really nice Job.
Does the flash hider disperse enough heat for the flame not to melt the muzzle as time goes on?
The best thing about the 3D printed version of the Flaming "Flame Pistol" is that the suppressor and nozzle are printed.
So if there is an issue after several firings, I can simply print a replacement part. :)
If the pressure gets a bit low (from the gas chamber) after a few shots, the flame itself starts to get a bit lazy, so I will
refill the chamber to increase the pressure to get a much sharper flame output.
A lazy flame has a tendency to engulf the plastic nozzle a little too much and start to warp it a bit.
Fantastic special effects !! That flame process is impressive. The internals you designed were a nice little bit of engineering and design. Well done.
