Kylo ren Costume pattern
Keivan
Hi all I'm working on Kylo ren costume and i wanted to reach out to see if any one can recommend for pattern for the clothes for the costume
i need the pattern idea if you know any one that has the pattern that they are willing to share?
also i need boots, neck seal, gloves, voice changer
all the best
Keivan
Hi Kevan,
McCall's patterns has a "semi-accurate" one...but you would be better served on the 501stSithlords website under the Kylo "soft costume parts". the "Knights of Ren" Facebook page. Several folks have sketches and pattern ideas.
Hope that helps.
Thanks Jaltrooper
i did see the McCall's Patterns and like you said its not the most accurate. thank you I will try the other forums you mentioned
best
Keivan
Hi Kevan,
Hope that helps.
all the best
Keivan
If you need a general idea of how the original patterns look like, you can always use these as reference material:
