devildog12
Re: Iron Man MK XLV 3D Print - Shoulder and handpalm p7
From what I've heard you can take a really thin guitar wire and try to shove it up a hot nozzle. That what I do and it almost always works. If your in the states, you buy a nozzle kit from http://www.makergeeks.com/exflsehounmu.html and you have the option to buy little "drill bit" for really tough clogs. This setup has been invaluable to me. I also upgraded my nozzles from the factory ones to high wear because some times I do print carbon fiber stuff. Those nozzles are great and have yet for one to wear out on me. The high wear nozzles are here https://store.micro-swiss.com/
I'm pretty sure this will be a clogged extruder then. I recalibrated the bed several times to make absolutely shure it is not the levelling.
I have a few issues that occured after a while that are listed here and the cause that occurs in each issue is the clogged extruder. So I'll be taking that apart this evening. Let's hope this solve the entire issue.
What's the best way to "unclogg" the extruder? I see one where you have to submerge the tip in acetone for 24hours twice. But that seems a bit over the top?
