Re: Inexpensive 5 days built Foam Iron Man Mk IV
Yes, there is a specific reason. Several in fact.
This foam is almost indifferent to heat, it does not melt down under the tip of a glue gun, or under the glue itself, that allows come very clean seams.
This foam has the perfect thickness (at least, the thickness I prefer), I can use it for every part of each of my builds. Except for gloves, but I always use some... common gloves instead.
This foam is flexible enough to build round shapes without visible edges or aliasing that seam lines usually bring.
This foam is available in large quantity at my local store, I can buy several boxes of 24 rolls untill my car is full, no need to preorder or watch for supplying.
This foam is available in several colors
I'm also a cutting wizard. Obviously. What did you expect ? ^^
The matt finish is due both to the paint, that is non glossy at all even on smooth surface, and mainly to the lack of finish, precisely. I can use my magic flexible transparent polymer varnish only outside and under weather conditions. It means almost never. Moveover it takes forever to get dry... and so it's true that nothing shines on my pics. And here the foam is not responsible, since it's coated with rubber. Otherwize paint don't stick onto it.
