Help with E-11 build
Re: Help
You'll probably get more hits and help if you create an actual title instead of "help"
Absolutely right. And there is tons of info on the e-11 teadily available here, use the search function to dig it up and see other builds. doopydoo is a search term you might want to use and hengstler.
I think you also need to express your actual needs and limitations on the project so that you don't waste the time of people posting information that does not apply to your project.
What is your price range for materials? You can spend over $1000-$2000 on super accuracy or less than $100 on a resin kit, or less than $50 on a toy to modify, etc...
You said it going with your suit. So do you want it light for trooping? A static display? etc..
What are your tool/skill limitations? Do you want to scratch build? Assemble a kit? Simply add on to and airsoft or toy? etc...
Resin kit but I can spend on super real if I can find it
