Hello
Does anybody know where to find quills? I need that for my Predator masks.
Please let me know
Here's the quick and cheap way-
First find a feather with a quill the proper size.
Mark the feather at the proper length.
Find a block of medium firm modeling clay and stick the feather in it. if the feather pulls out with clay residue on it, you need the next firmest grade clay. When you find the grade of firmness where no clay comes out on the quill, shave the surface of the clay block down, about 1/16th to 1/8" deep, leaving about a 1/8" high wall around the outer edge. Now poke the feather into the clay block about 500 more times, to the desired depth.
When you're done with that, take some baby powder and literally fill the entire surface, holes and all, then shake it all back out, leaving a fine coating on all surfaces.
Now you're ready for the resin. For something like this you might want to pre-pigment your resin now, but you can also spray paint them black later. Mix up some resin thats at least room temp so it'll release any trapped air easier, and pour it over your impromptu clay block mold. Gently shake and jiggle the clay to work loose any trapped air and let the resin flow into all the pokes. The baby powder will break the surface tension of the resin and suck it down into every little nook and cranny.
When the resin cures all the way, you should be able to pull off a 1/16th - 1/8th thick resin sheet w/ 500 quills sticking out, that are ready to be clipped off, painted and mounted on your mask.
Take pics! I just made this up as I typed!
-Sarge
