Help in finding a good VACUUM PUMP
29 hg is pretty good for what you are doing. another thing you can do that is recomended on smooth-on's website when working with their crystal clear 200 series is to vac it then pressure pot it. im building a pot now from a harborfreight paint tank that i can vac then put 60 psi to it. my pump will do 30hg but it takes a while to pull the full 30"full vaccuum" the pup you have will prolly do the 30 if you leave it running and everything is sealed good.
Thanks, but it will not go to 0 to 29-30 I need a good one that is fast.
i was reading yesterday that robinair pumps instructions state.......
"replace the oil after each use"
that can't be right can it?!
-z
I use an old Edwards speedy vac. It pulls a full vacuum in about 2 mins and I use a stainless steel tank about 2 foot deep and 2 foot wide. I got the whole lot off eBay for £200 which is a bargin for something of that size.
I've used it loads of times and never replaced the oil yet.
Ive missed loads of bargains on ebay due to "pick up only" .living in the north of scotland really sucks sometimes............
One time(i live in So-Cal) I saw a huge vacuum former with a built in heater for $350.00.... It was in Indiana with Pick up only:cry... oh well
I bought a Robinair pump years ago, and haven't changed the oil yet as it still looks clean. For the tank, I converted one of my 5 gal. pressure pots- it's big enough to hold a 5 gal. bucket, and pulls about 29 in. hg in 2 minutes. I leave the silicone degassing for about 5 minutes after it "falls"- never had a problem pressurizing molds after degassing.
I use the motors from old fridges. They'll pump down to 29, and they're free. Put the hose on the other end and it's a compressor. And it's very quiet. If it stops working get another.
