Archive&Future
It seems I miscalculated the frame a little bit so I had to make some hack-job modifications to the mandible openings before the wells would fit correctly but hey ho there we go.
Anyway last week I hand cut these new mandibles from styrene using a laser-cut MDF template and an ultra special jig (read: a plank with masking tape and a drill).
I started test fitting my resin sidewalls, but of course seeing as my corrected mandibles are shorter than that of the OOB MPC kit, I'll need to strategically cut and splice the sidewalls to the amended length
I also cut out the jawbox intakes and started detailing. I forgot to take any photos of the process, but I spent a long time filling, sanding and reshaping the shortened jawbox, and it still needs a lot of neatening on the top
Planed away all those moulded actuators too, and attempted to scrub away as much paint residue and flakes as I could
I used my resin inserts for the mandibles and glued them all together....again I forgot to take photos of the underside and the other views but you can see from this one here that they look pretty noice
I'm dreading all the plating the mandibles will need but I guess it's just gotta be done!!
