Originally posted by gavidoc@Jan 6 2006, 12:26 PM
I don't see how you are getting the T-track running into the suppressor Gabe. What you are viewing as the T-track on the suppressor is the scallop in the suppressor.
I never said it's running INTO the suppressor, only that the line Chris and you believe is its bottom edge runs straight over the shamfered edge of the suppressor and over one of the scalloped cuts.
DUDE, YOU CAN SEE THE LINE CONTINUING THROUGH THE CUT. And you ask what
I'VE been smokin?
Also, this is an UNPUBLISHED PHOTO. Again, UNPUBLISHED PHOTO. There is no need to "airbrush" an UNPUBLISHED PHOTO.
Are you not realizing that you are saying that an Unpublished photo has been retouched.
What I think is, is that after trying to retouch the tilted suppressor to make it look centered again (because Harrison looks so dashing in this action shot and they wanted to salvage the photo), Lucas saw the reprint and said "you gotta be kidding me, look at that mess. This one goes straight to the archives." You just helped me win that argument, Gav. :lol
With respect to your red-blue-green overlays, how about addressing what I wrote and diagramed? Better yet, please account for the step in the rod toward the rear and the sudden blurry blackness next to the switch. And please don't tell me it's residual black paint.
Chris: no insults were intended - you know I tend to be passionate about my research, and I tried to keep it entertaining, is all.
You responded:
You're right it doesn't. Your CAD just proved that the left side antenna could not possibly be there which I stated in my post.
I believe the rotation on your CAD is slightly off and that the scope would easily hide the ridge of the T-track in that photo. Your CAD is probably more perfect than the prop was so aligning it might be difficult
I agree with you there - I already said I centered the t-track. However, if this was indeed a resin casting, why oh why didn't the property master replace it when it broke, not to mention glue it on centered?
Again I agree the CAD actually looks very good. Your rotation is off again though - look at the large gap between the scope and gun barrel in the CAD vs. the photo.
Thanks for the compliment.
What you're referring to is the forced perspective in the CAD, which makes the scope appear closer to the viewer, thus increasing the gap, but the location of the scope is irellevant to this debate.
Maybe you're assuming that the cap screw is perfectly centered to the bottom of the Mauser to guide your rotation. It is definitely NOT centered which you prove later in this post.
No assumptions, Chris. I'm not sure what the cap screw has to do with anything, but it's not driving the suppressor's orientation, if that's what you mean - it's purely cosmetic in the CAD. Besides, the rotation angle of the suppressor is irellevant to this topic - unless you're conceding that the t-track is jammed in there to compensate for the off-centered and tilted suppressor, and somehow got rotated along with it? That would make more sense: use the resin Merr-Sonn greeblie cast to realign the suppressor. That would make it a FUNCTIONAL mechanism, not a cosmetic one, as I've been asserting all along.
If you rotate it correctly and then puch the suppressor down as you said it needs to be I think you'll find the CAD will even better match this photo
Not necessary for this debate - I've already conceded before your response that I idealized it.
I still can't believe that you think this pic was heavily retouched. The "evidence" was weak at best, but really doesn't disprove anything about the detail parts anyway. We have SEVERAL pics of this blaster showing these details on the barrel. Are you saying they added the details in this pic? You seem to be saying there is nothing there which there obviously is. I'll debate what it is, but debating whether there's something there or not is foolish
and
I count at least 3 pics that show some proof that the details are the same bits as used on the Merr Sonns. No, we don't have solid proof, but we have enough to believe that the parts are what was most likely used and that they were consistantly present on the blaster
"These details?" Chris, even for you, that's quite a stretch. In Sergio's interior Falcon shot, maybe 6-7 pixels betray "something" on top of the barrel. In the OfficialPix shot, we see a black glob with no rod - where
IS that rod, Chris? Gav? It should obsure part of the ejection port area or be seen between the barrel and the scope. But it's not there. 2 pics down. That leaves the Chronicles top view, which is open to several interpretations because it's so dark and detail-poor, and finally Jason's shot, which my diagram clarifies even further to be a blatant manipulation.
Would you rather have a broken T-track and one antenna? Granted we have no photos of the assembly complete so it would involve some conjecture. It's different than trying to make a case for the Imperial disc on the side though. In that case I believe that's what was there at some point pre-filming buts thats only my best guess based on other props
Ah, now we're finally getting to the crux of the debate: "To Be.... Or Not To Be... That Is The Question."
I never contended that there was nothing there, Chris, only you won't find any evidence of these greeblies on the blaster when the suppressor was centered. When it WAS off-center, I assert that something - perhaps a beaten-up Merr-Sonn greeblie casting - was used to partially realign the suppressor. But if you're going to reconstruct something and idealize it based on WHAT YOU SEE ON A DIFFERENT PROP, then I say you're misguided at best. If you're going to do that, logic demands that you return the imperial disc as well. You don't know at what point it fell off, and using your own arguments, just because there's no compelling or conclusive photo evidence to prove it, doesn't mean it wasn't there. The fact that we know a pre-production Han exists with no mystery disc and then it appears in the film with one should be all the evidence you need to restore it, for the exact same reasons you want to restore a Merr-Sonn feature on a different prop.
That statement was based on an eyeball guess. Note how the white highlight on the lower one's barrel seems to extend back further than it should. I never measured/compared the things real close. You can match up the lumps though so I believe they are from the same mold, but maybe the muzzle was a seperate mold. That might explain how the muzzle has interior detail not on the actual suppressor, how it was turned 90 degrees, and how a seperate muzzle shows up on the Jawa/Greedo gun. I'll have to go back and look at some of my other pics and see if the ESB/ROTJ stunt came from the same mold as these 2
Chris, that's a non-concession-concession if I ever read one.
If they made a mold with a 90-degree rotated suppressor, makes more sense that they made a second mold without it. Just a few posts ago you were arguing that they molded the suppressor farther out on the barrel. Now you're saying maybe they made a seperate mold just for the muzzle, which would mean that the one we see rotated 90 degrees was glued on. You have no proof, yet you put out the possibility, and you make factual statements based on belief before due diligence research. At least when I've stated something as a fact and later was proven wrong, I took responsibility and backed it up with evidence. Which reminds me: why on your site do you still define the MG81 suppressor as a fire-extinguisher nozzle and use a discredited photo? Perhaps you should update it before staking out any new hypotheses... :unsure
By the way: the Jawa & Greedo guns used entirely different muzzles and gun bases, so why even bring this up?
- Gabe
