Done / Completed Greedo Blaster DT-12 Machined Aluminum Parts
Ok. Thank you for answering this. Some of the parts look off on the size. I have some of the original vintage pieces. I’d be willing to measure them or send them to you if you like.
Waiting lists created. If I missed any one, just post a reply with the parts wanted or send me a pm.
Also, it was recently discovered that there are two "Pontoon" parts on the Greedo Blaster and I'm going to need at least one more (and possibly a flash hider) to complete my blaster. Since these are parts are no longer being made, I can cast the one I have in black resin. If any one else needs a set, feel free to post a reply with the number of sets needed. Thanks.
Waiting lists updated.
I have more photos coming along with research details on the barrel extension and side points. I've made some interesting discoveries on these recently. Thanks.
I've add you to the list.
By the way, the pontoons will be cast exactly like the originals (which are partially hollow) using a two part mold.
Same goes for the grill/flash hider.
Edit. Could I also add two Sets (ie, four total) of these:
I made another "point" prototype part. This one has a threaded hole in it and the angle is slender:
The flash hider barrel may be what's in the reference photo above, which is interesting to say the least. I'll research it this weekend and post some photos.
So I mistakenly thought I had the side missiles in my parts box.
so, I’ll actually need the entire set of parts, including the side missiles, points and Side rod.
4 Side Rod (2x per blaster): $19 each
4 Side Rod Point (2x per blaster): $15 each
2 Barrel Extension: Depending on price
I would like to increase my order. I just finished this one and want to make another.
I just finished my research on the side points and barrel extension.
Every thing looks good, so I've started the run of side points and rods.
This is a last call for side points and rods, so if you haven't posted a reply or sent me a pm, you've got until Monday night (4/13) at the latest to contact me before I close the waiting list.
