freezen2001
So this is the second time I've attempted to make a plaster cast of my girlfriends face using alginate and plaster bandages. Still messing up!
first, put on the bald cap.... layed some plastic out like it was Dexter's kill room, and put a few old couch cushions under it all to make her comfy. Had her put some vaseline on eyebrows and eyelashes, and nivea cream on face to keep things from sticking!
Put 7 lbs of water (70 degrees) in a container and added 1 lb blue alginate powder and mixed and attempted to cover her face. Again... it was so runny that it all ended up in pools on eiter side of her. I kept scooping it up and putting it back on top to watch it run down again. Not until it started to set up after 7-8min that it would make a 1/4 inch depth without running down like water.
Then covered it with plaster bandages. Covered her face and neck hoping to get a cast of both connected. Did about 3-4 layers and let harden about 20 min.
Then for the moment of truth! It was horriable... the alginate was too thin around the edges, it tore from the chin down... had tears in it... had to use clips just to hold it up against the plaster bandage outer shell thats spoused to hold its shape!
Finally..... drumroll please..... the anticlimactic ending... a lifecast that looks like sloth from Goonies! Arrrrrh! I've noticed lots of videos for lifecasting online that use a much thicker type alginate. Am I adding too much water? I've weighed everything out on a digital scale that goes down to ounces. Anyone have any advice or suggestions for me?
