McKilligan
So, it's been a while since my last big project, but I've started something new. I started brainstorming for the project earlier this year, when I started seeing the pre-release materials for DS3 with the red knight plastered all over them. I decided to start work on him before I learned that
he was actually the final boss, which came as a very pleasant suprise.
Anyway, I started work on it way back in early Feb/March and so far, I've finished the sculpt of the helmet and have made good progress on the cuirass, as well as making a ton of chainmail for various pieces (which haven't been assembled into something wearable yet - chainmail is a stupidly tedious process).
The helmet was built with a steel wire frame, which I then covered with super sculpey, baked and primed with black gesso. I don't think I would recommend this process - Sculpey is a finnicky material to work with when you need something this size, and is super soft so it has a tendency to 'sag' unless properly supported. If I had to do it again, I would probably make a much more comprehensive frame for the clay to adhere to. As it was, getting it into just the right shape was a huge challenge. At any rate, I'm very pleased with the final result, and it fits my head perfectly.
The armor is being cut from EVA foam sheets that I bought from a local art supply store (I live in Seoul), one is about 4mm thick, the other about 2mm, and fit together with hot glue. Eventually, I'll be using the same process as my Artorias suit - primed with woodglue, then a polyurethane resin.
Here's a brief progress log so far -
Skull/Helm
Skull/Helm 2
Early Cuirass 1
Early Cuirass Interior Closeup
Cuirass Front
Cuirass Front 2
There's still a tremendous amount of work to be done, but things are accelerating quite nicely now. I'm optimistic that I'll have the project ready to go by fall.
