Daft Punk Helmet Need Help!
nickchampish
My friend is a big fan of Daft Punk and his birthday is in June and i think it would be a sweet gift to give him a helmet. Now i havent tried anything crafty but i think by June i could get some stuff done i want to do this helmet. Heres a pic and awesome video about the helmet but i havent the slightest idea on mask/mold making process i HOPE some of you can maybe help me out with tips or steps thanks alot guys!
-Nick
YouTube - How to make a Daft Punk helmet in 17 months
I think I'm a little lost here but I will try to answer in the best way I can. There are several different ways to go about building the helmet.Ask Volpin or look in his thread to see how he made a master by covering a frame in expanding foam then carving away on it then going to further methods. Another way is to sculpt the helmet then mold and cast it, and finally if you are only wanting to make one without as much work as the other methods I would suggest looking for a pepakura helmet for Guy several already exist all you would have to do is build it out of paper, resin, fiberglass, bondo to smooth it out, sand it down. If Volpin sells the visor I would check with him on it Visors really are not something I am good with especially one shaped like this.
Hi Nick,
There are a few threads here about Daft Punk helmets, if you use the search function, that should be able to give you an idea of what it takes to make a Daft Punk helmet.
In particular, the helmet you have linked to was built by a member here who goes by the name of Volpin. His build thread can be found here.
I'm going to take a shot in the dark and assume that you do not have much prop making experience? If that's so you may not want to set your goals as high as Volpin's helmet.
For some tips and tricks on how to make Daft Punk helmets on a budget, or for prop making novice's, I would recommended visiting The Daft Club, as there is a huge thread on the subject and a very welcoming and helpful community.
Good Luck!
Didn't someone offer a kit a while back in the Junkyard? Should'a snatched that one up myself...
Wow thank you guys all very much for the tips and links! And no i don't have much experience with prop making but sometimes i like to challege myself i guess. Im going to look into this more a daft helmet would be amazing to make and or own again thank you guys incredibly for the replies it means alot!
-Nick
I hope the pictures in my profile will serve for future projects
Free MinD (F
