Cyborg Ninja (Metal Gear Solid) - pics of completed costume
pandamajik
Member
A quick intro about me - I started off making some Gundam model kits and one figure resin kit and eventually found myself going to anime conventions about 3 years ago. I made a sword for my Strider Hiryu costume 2 years ago and that's pretty much the only prop I've ever made. I sewed a Roy Mustang costume last year and so I've decided my next costume is going to be ambitious. As a result, this is my first time for a lot of things (i.e. Pepakura, resin, fiberglass, and pretty much everything else here).
I'll preface this by saying that I have only played Metal Gear Solid and none of the sequels. However, I loved the character design for Cyborg Ninja and I decided to make this my next cosplay project. I'm starting with the iconic helmet.
I found a version of the helmet that someone had made and unfolded in Pepakura. I printed it out and proceeded to make it out of cardstock. The only thing is that it was designed too narrow so it would end up being too tall if the width was made to fit me.
I decided I'd give 3D modeling a shot and started creating the helmet in Blender. I made the helmet in one piece for 2 reasons - I wasn't confident in modeling multiple pieces that need to fit together and it would be easier to model just a single piece. The plan is to make the helmet and then cut it apart later.
I got a bunch of reference images and took some pictures of my head with the helmet superimposed so I could use it as reference when making the 3D model. I don't really have a background with 3D modeling so I had to read a lot of tutorials first.
Next, the finished model is exported to Pepakura and unfolded. This is then printed out onto 110 lb. cardstock and then cut out.
[size=+2]Some people have been asking for the Pep file so here's a link.[/size] A word of caution - this is my first real attempt at 3D modeling and Pepakura and I did all the work myself so it's hardly as good as some of the other work out there. You may find some areas will need more filling. It's also a good idea to add some supports in when doing the resin and fiberglassing.
The pieces are scribed with a ruler along all the lines that need to be folded so the folds are really crisp. The pieces are then glued using regular Elmer's white glue. A thin layer is optimal so you don't have to hold it for minutes waiting for it to dry.
The way the helmet is designed I can't put it on to check the fit so I was only able to check for an approximate fit when half of the helmet was glued. There helmet narrows in size around the mouth area so it can't just slip on.
I actually made three different Pepakura models. The first one was using a Pepakura model someone made and unfolded but after making the forehead piece I didn't really like the shape so I decided to make my own from the beginning stage of making a model. The second one was a bit small so I rescaled and the final one came out the right size.
Here's the profile of the Pepakura model.
The supplies I'm using for resin and fiberglassing. The chip brushes were from Harbor Freight. Be sure to wear a respirator when using resin and fiberglass. A simple dust mask doesn't stop the organic fumes.
The entire outside of the helmet is coated with a layer of resin and then the inside gets some resin and about 2 layers of fiberglass cloth. Make sure to tap the resin into the fiberglass and not just simply brush it on. 2StoryProps has a nice tutorial on the process complete with videos. Also, resin can eat through certain plastics including that blue cup you see there. I know some people use plastic cups so I guess these were just cheaper plastic. I had some Yogurt containers and that worked fine.
When the fiberglass and resin dries the helmet becomes very stiff but still remains very light.
Body filler is then put all over the helmet and the cycle of body filler and sanding begins. Spreading the body filler in thin layers helps to minimize the amount of air bubbles.
I started off using Bondo brand body filler but it's not the best to work with in terms of spreading and sanding. I heard about Evercoat Z-Grip from a friend a while back and decided to give it a try. It's specifically made for automotive use so you can only find it at certain stores. I got mine at Carquest.
Here's some body filler being mixed up. It has a slight greenish tint. I also picked up a spreader which is made of flexible rubber so you can pop off the hardened body filler when you're done.
After a few rounds of body filler I sprayed a coat of gray primer to make it easier to see what needs work. The gray primer I'm using is Rust-Oleum Automotive self etching primer since I had some left over from working with resin model kits.
I decided to pick up a contour gauge so I could make the helmet more symmetrical. I also played around and drew on what the final helmet would look like.
Some areas are patched and then sanded again. Here you can see the various layers of body filler and primer. Light gray is Bondo, dark gray is primer and the light green is Evercoat Z-Grip.
Another coat of gray primer to check for defects. Then it's time for the spot putty for small defects. It was a lot cheaper to get the super huge size of spot putty.
A coat of brown primer. Here I'm using Krylon brand since it's cheaper.
If you look closely you can see that I filled in the right cheek (left side of screen) a bit more to match the left.
I made a paper template to get the shape I need to cut out. I think I made at least 10 different versions. You can also see the string that I'm using to mark straight lines for reference on the helmet.
I tried using a Dremel to make the lines but it was difficult to get a really straight line which is evidenced by the horizontal and vertical lines. The pentagon was first drawn on paper using this method and then traced it on to the helmet. I used two layers of masking tape for a bit of added thickness and then scribed it using a scriber then went over it with a small needle file.
The pieces were cut apart using a Dremel. It was actually cut apart before the last picture but I forgot to take a picture of the pieces until after. The problem of using the Dremel is that the cutting tool isn't the thickness of a piece of paper so you end up with approximately a 2mm gap in between all pieces.
I'm currently working on filling in all the gaps between pieces so it comes together cleanly. I tried the helmet after it was cut apart and it does indeed fit me. It's snug around the ears but it's not too bad. The reason for this is that there's about 0.5cm extra thickness due to the body filler to get the outside smooth. I probably don't need it this thick if I cast it. My initial plan was to cast this if there's some interest so if that happens there will be more room around the ears.
I do have plans for making the entire costume but I figured I'd handle the helmet first before going on.
Re: Cyborg Ninja (Metal Gear Solid)
Dude awesome! Im a real MGS head. lol iIwould love to build one. Care to hook a brotha up? lol I havent started by pep builds because I dont have windows. Yea i know sucks to be me but hey thats what these forums are for right? A lil help here... A lil help there and you got yourself a build. lol Well cant wait to see ow this comes along. Looks like your gonna breeze through it. PM me if ya care to work something out.
Haha I don't think I'm going to be "breezing" through this since I'm learning as I go. I can PM you my Pep file and even my original 3D file but I do have to caution that there's probably a few areas that could have used some refining. If I could do it again I would definitely have built it with more polys since the pep is less time consuming than putty work. I also built it without struts so part of the very back warped in a bit causing me a headache when matching the symmetry. Let me know what you need and I'll PM you.
In terms of scaling I had pictures of my head both in profile and front view with a ruler held underneath so I could measure the dimensions accurately. Add a bit for wiggle room and that's how I did the scaling.
Great idea for a build, I'd love to have one to display with my signed copy of Metal Gear Solid.
I would love to get a copy of the pep file. I think the kamen rider helmet could be modded into it.
Great build btw looking forward to more updates.
PM me and I'll give you a link to the file but I have to caution that it's not nearly as polished as many of the other files around here because I did all the work myself (3D model, unfolding, etc) and seeing as how I have no expertise in either field it's fairly amateur work. I didn't build in supports so make sure to have some when you make it or else you'll probably get some warping. Aside from that if anyone wants the base model to improve upon I would be more than happy to provide that in any file format since I'm pretty sure I can export as various file form from Blender.
Thanks. I've been having some trouble with filling in all the gaps where I cut stuff apart so that the pieces will fit back together nicely. Just about to head to Harbor Freight to pick up a few things so I should have some more progress tonight.
thanks for the file. ive cut and scored it last night. now time to hot glue it together. and ould you believe i never knew what a contour gauge was till this thread? lol n e how thanks again ill keep u posted....
I actually learned about the contour gauge from a picture Volpin had during a Daft Punk helmet build. I got a cheap one from Harbor Freight for less than $5. You have to be careful using it since it doesn't "lock" in place so you have to watch for it shifting on you when placing it over the other side.
After I cut everything apart I started to work on cleaning up the edges and filling in the gap that resulted from using the Dremel to cut it apart.
I taped everything together to check for what areas needed more work.
You can see here that there's a gap in the fit of some pieces in the horizontal direction, namely the bottom pieces. This is because they're under stress but because it was one piece before it wasn't evident. When it gets cut apart they naturally flex in a bit to relieve the stress. I can just skim some body filler on those areas later.
The way that I'm fixing edges is by using the "bondo squish" method. I'm using aluminum foil there because body filler doesn't stick to foil very easily. I cover the edges in some body filler and just lay it down on a flat surface. When the body filler dries I have a nice flat surface and both sides are also parallel with each other.
For the gap where two pieces come together I had to employ some clamps. I covered the clamps in aluminum foil too so they don't get covered in body filler.
There's a round piece in the front center of the helmet that will eventually contain an LED. I cut a circle from sintra and hot glued it the forehead piece of the helmet.
I probably should have done this a lot earlier. The two cheek pieces are not totally identical because of it being cut out with a Dremel and I can't make perfect cuts with it yet. So I used my original paper template and made two sintra templates which I sandwiched together and finished the edges together so they're more accurate.
I'm currently in the stage of heat forming them to the actual cheek pieces so I can get the cheek pieces to match these templates. That should make the cheek pieces more symmetrical with each other.
Great job! I'm a big mgs fan and it's awesome to see this come together.
Nick
Looking really good! Not sure if you would but can you post the pep file for that?
You are not really building this costume....
This is my favorite character of the whole Franchise.
Keep going! I'm tuning in for this.
You don't like Snake, or Big Boss, or ... Otacon? :lol
