Re: Classic Viper Build-up -- FINISHED!
I've got one of those on my bench right now. It's from the Jim Key era. The biggest problem with any of the Viper replicas out there is that they will be smaller than the original, due to shrinkage and the number of times this thing has been molded and remolded over the years. The overall length of the replicas is about 7/8" shorter than the original. Actually, the whole thing is smaller in mass - not just length. Short of completely remastering it, not much you can do about it.
My next biggest complaint is that the engines aren't really round. Looks like they've been squished at some point and it has carried over. I thought about Dremel-ing out the centers and putting some brass tubing in there (the real thing had a brass tube for the lights and exhaust that stuck out slightly from the rest of the body), but I thought it would look wonky. I wound up cutting off the entire afterburner can section and am in the process of scratchbuilding the area. I deviated from the Leopold rail car part for the engine cans and used Evergreen sheet styrene beefed up with strip styrene. It matches up well with the parts that I replaced, even if it is a little bit smaller than the original kit parts they used. The triangle arrangement of the engines is not symmetrical and like I said before, the engines aren't perfectly round. This shows up when you create a base plate that is perfectly round and symmetrical and try and mate it to the body. I'll have to just place the engines in position relative the rest of the body and just live with it. The rear hatch cover has been remade, but again, it is a compromise as the kit parts are full size and the model is slightly smaller.
Some of the filming miniatures had their intakes hollowed out, others didn't. So, no matter what you do, I guess you are accurate.
You can also add a few little pieces here and there. The hero version (the one featured in the Klambach book and most of the publicity shots) has some little details on the sides of the nose that are different from the other ships.
The little detail pieces inset into the fuselage by the laser cannons could also use a rework (though maybe Jesse took care of that already?).
And the really bold could always do the landing gear version.
Gene
