"Captain America, how exciting!" TWS TFA Rescue USO and Ultimates WW2
Re: "Captain America, how exciting!" TWS concept and TFA
Jwave, that is a great looking jacket. If you don't mind where did you get it?
If the desire is to look exactly like the photo.
For the rips, I'd print the photo blown up to the same size as your jacket and transfer the cuts with a chalk pencil. Use an sharp exacto knife to cut the shape of the openings and fray the clean cut edges with a file or sandpaper.
For the burns and stains, you can use layers of slightly darker leather dye, shoe polish, or garment water proofing spray unevenly applied to the jacket. What you do needs to remain flexible so I'd rub in saddle soap or a good leather conditioner.
The elbows and high points of the folds will wear lighter than the rest of the jacket just from use. To speed up the process, wear the jacket for a couple of nights for the folds to develop and then buff the areas with saddle soap and a cloth. The areas should lighten up a little.
For the damaged zipper, cut it with a grinding disk, do the rest with the exacto knife, and hand stitch the ends of the vertical seams so they don't open up more than you want.
Additional weathering/wear can be done by tossing on the ground, rubbing it against concrete, or using a tumble dryer on no heat with gravel and sand. These depend on how thick the leather is, if you don't mind tearing up your dryer, and doing this before you do any cutting.
OR to save the jacket for street wear:
Try some leftover fabric from your USO shirt and stick it to the jacket with 3m adhesive spray.
Just spray the back side of the fabric, not the jacket, wait for the glue to dry and stick them on.
As long as it doesn't get wet should they stay attached.
I'd test it inside the pocket flap to see if the dried glue reacts with the leather and if that is good, only have the patches on when in character.
Hope this helps and please share the results.
Edit: Just noticed this was your first post. Welcome aboard. Thanks for letting me be the first.
Thanks again Fly4v, I just figured I was messaging you enough I should just suck it up and do a forum post so others could learn from your continued wisdom!
First I got the jacket on ebay, just search for captain america jacket, usually ends up with something like this .
Looking closer at the movie photo, it looks like the whole jacket is kind of worn in or bright in a number of areas, and only really darker near the left torso region. I'm hesitant to try to brighten the whole jacket because I've had some bad luck attempting it on a lesser jacket last year. Either way I may have to find a leather store near me and see what I can find. On my 1st attempt jacket I tore it up in the right places and tried to just use black paint but it looked too... well, painted on! Not enough blending. Though I do like your advice on sticking parts of the USO shirt under the jacket, I'm leaning more towards actually just taking the exacto knife to the jacket to allow for ventilation. Sadly these cons get pretty hot VERY quickly and a heavy leather jacket isn't doing me or the crowd any favors!
I'm still in the middle of my heater shield, stripped it and sanded, now I need to sand down some of the white paint I sprayed on as a base coat. Will try to remember to take pics! Thanks again!
Thanks for the free bump and I wish I could have cut up my jacket for ventilation. My wife likes the look and she thinks I distressed too much.
Being in SoCal are you headed to San Diego Comicon?
Hate to admit that I have yet to do a Con.
A shameless bump to show off my very minty Marvel Phase One Set. Get it now if you haven't yet prices are going up on Amazon.
[url=https://postimg.org/image/wluozmiqx/][/URL]
Edit: Since the case and cube are about 3/4 scale, plan to use this to make a 1:1 more movie accurate copy sometime in the future.
This entire thread = mind blown & overloaded with ideas that will surely get my into trouble....
Started working on the Winter Soldier TFA Abs panel so my suit can be closer to the new movie but can still convert back to the original.
[url=https://postimg.org/image/ngqxjdeyx/][/URL]
After the abs are done then I'll figure how to redo the sleeves.
Edit: This is going to be done without buying anything new. It has to be done exclusively with scraps.
I think I'm in love with this thread. Awesomeness all around! Amazing work!
[url=https://postimg.org/image/p8jwecqmx/][/URL]
I really like the new ab panel with the Avengers' style paddling made from craft foam when compared to the original made with quilt batting.
The new panel doesn't bunch and covers last weeks laziness that would have been very visible.
Do think the side white panels should have been made wider. All the white panels are the same width and believe too much red is visible.
Now I need a picture of the back of the sleeve to confirm the shape of the new blue panel.
Plus, figure out how to hide the leather straps and buckles when wearing the new sleeves.
Fly, looking great, where di you get the pictures of the revised TFA suit?
N/M found em, but your stuff still looks super awesome as always!!! :)
Thanks!
Here is the work on the new sleeves.
[url=https://postimg.org/image/ujysz2s55/]
[/URL]
When these are done that is where I will stop on the Smithsonian Suit but have a good idea that the new WS TFA pants look alot like the ones for the "commander" uniform just in light blue HBT.
Looking amazing man! Can't wait to get started on mine!!!
Thanks, Will you be doing yours from scratch or an upgrade to the first suit?
Here is the old abs and undershirt verses the new parts.
[url=https://postimg.org/image/thomg6tsp/][/URL]
Best part about the new uniform. No cross belt.
[url=https://postimg.org/image/vnixalx89/][/URL]
[url=https://postimg.org/image/ree78fm95/][/URL]
Sorry for the bad focus.
For the leather arm straps, thought about stitching large button holes and passing the straps through and adding a piece of velcro at the bottom of the shoulder pad to attach to the shirt. Most likely the suit will look like this for sometime.
Edit: Also, need to redye the tops of the gloves.
I was looking for some reference pictures for the POW Rescue costume I'm working on and came across this: steve20.jpg
You can clearly see the ends of the general purpose strap on each side of the suspenders, which I haven't seen before. Also it seems that he wore a white webbed belt.
Nice photo and very similar to the one in the auction catalog.
I believe the belt is tan but don't know if it is the open or closed buckle.
Onlinemilitaria.com - What Price Glory - US Officer Trouser Belt
I wear a vintage date 44 belt with open buckle but the free running end isn't that long.
You're photo confirms what I had suspected and EDIT: "posted June last year." My suspenders are the wrong pattern. They should have been the version below that has fabric near the D ring and not metal.... but the GP strap is only on right shoulder.
First Pattern M1936 Suspender
There are two version of the the M1936 suspenders, make sure you get the first pattern not the metal reinforced.
Not like I'm buying a new set, maybe after I get a better jacket and shirt.
EDIT: June last year, wow, time went by fast.
steve11.jpg If you zoom in on this picture (ctrl and click) you can see the metal under the D ring. So I believe it is the standard pattern of 1936 suspenders but they have been modified for the film. It looks like they took two general purpose straps and placed them over the original suspenders from the front of the shoulders to the back on both the right and left, so that in the front the end D ring from the strap just hangs over that metal part. I'm not sure how else they could have done it without completely redesigning the entire thing.
