That black paint really looks sharp when contrasted with the light gray! I really need to make the trek out to go to one of your conventions some time...
Hi Gang,
Don't you think it's time for an update? Why not! :)
Cut more holes on the instrument panel
Still a long way to go before paint - have to figure out the monitor configuration and the new button panels on Han side
Now it was time to make the jump and get these LEDs in place... This was scary, fun and time consuming! I have to drill out ALL the holes to make the LEDs fit. The next cockpit will have everything done by CNC to make it MUCH easier. Anywho...
The drill pulled up A LOT of the paint and MDF so in some cases I had to sand these areas smooth and repaint - UGH
I'll blend the lines later
And away we go! Each colored lens got the same color LED for maximum effect
My poor little fingers.
Done
Done - in some cases I even had to go in with a paint brush and clean around the edges. But we're also laser cutting 1200 little acrylic donuts to fit around the LEDs to help hide all the imperfections
Backside
UGH... I wish I could have used the CNC
A little Iron Man coloring going here
Moving on to another panel...
Once I drilled these holes I had to drill out new ones to match the ESB panel
What a mess!
I test each LED before installing it. Very time consuming
Done!
NEXT!
I then drilled a hole to install a rotary switch
All Done
UGH... the panel I have been dreading!
Top Part - Done. You can see how the edges need to be cleaned up
Paint brush in hand
Before
After - I missed two holes in this section (insert comment here).
Switching gears... I'm working on this greeblie
Primed
First coat of black. But I think I'm going to layer with acrylic. I can add more details. More to come!
This greeblie mounts to the back panel of the armrest
I then began to pinstripe the nose access panels
There is SO MUCH going on with these panels I can't wait to show you guys!
More pinstripes
More to Follow! :)
This part has been posted on partsofsw´s facebook-site (see bottom left corner of the MF cockpit, right on the center console)
Markus
Hi Gang,
Another update!
While taking a break from taxes I decided to finish up the back instrument panel covers - not sure why but I was really dreading this part...
First thing... knock out Chewie's upper back panel
I then made this steep cut for the lower panels
Which will cover this area
Without boring you too much... I made all the cuts, sanded smooth and bolted into place
Overhang to sand - I left the overhang to ensure I had the same angle as the instrument panel sides
Chewie's side
HMMMM... needs some primer
Sanded, smoothed and primed
All the edges and the back and lower panels will be painted black - this hides any and all imperfections (thank the maker)
In place
Definitely needs some paint!
I then decided to dust off the ol console and light her up!
More to Follow!
I love viewing updates in this thread!
Hey KB! Thanks so much! :)
it's coming together!
Hi M,
Slowly but surely... Don't worry we'll hold together! ;)
Wow. Really looking cool, guys! Awesome work!
Hi B,
I noticed you're new to the forums - Welcome! Thank you so much for the kind words. There is always something interesting going on so be sure to visit. :)
http://i785.photobucket.com/albums/yy138/OdiWan72/ESB Cockpit detail_zpsuksiioyi.jpg
Markus
Hey M,
OH WOW! I have ALWAYS wondered what the heck that thing was! GREAT FIND! I'm smilin' :D
EDIT: It really looks like part of an air cleaner filter housing from a 70s auto...
Markus
Yeah, that's definitely an air-intake duct from the air cleaner of a 60-70's vehicle. That's the bottom view. The larger end was attached to the circular housing where the air filter sits, and the smaller end is where the air is drawn into the housing. The hole on the right side of that photo (that piece that looks like a section of pipe sticking up out of the part) is where a flexible metal hose was attached that ran to the exhaust manifold of the car. That allowed the engine to draw in warm air on cold days.
Hi Gang,
Another UPDATE!
As many of you know the cockpit started out as the ANH version then slowly morphed into the ESB cockpit we all LOVE! With that, I decided to redo two of the back wall panels to match the ESB layout. This redesign removed ALL the colored LEDs and removed several LED button panels ("oh darn" said Daniel). There is limited pinstriping and only 9 1" tiles per panel - fairly simple. Along with these changes, I am finally addressing the "radar" panel - I cut the hole for the "radar scope" too high and was never able to properly dress the panel.
Popped out all the LED panels
Removed any and all greeblies
I traced the basic shape of each panel before carefully removing from their frames. I then cut and adhered the new MDF to the frame
Once the filler dried I was able to start drilling holes - in their CORRECT position this time
There is a large greeblie that sits just to the right of the LED panel - we're fabricating that out of acrylic (x2)
Painted
Panel #2
Painted
WHEW... Pin striping basically finished
A VERY complex design
The panels fit perfectly!
With LED panel - all the LEDs in the panels are white. No colors at all. There are only 2 blue 1" tiles
The "radar" panel was/is going to be tough! I basically have to draw out the pattern of the pin stripes so I know where to drill 3 holes... ugh
The toughest part will be successfully creating the 3 curved pin stripe designs going around the black "radar" surround... MORE to follow! Plus... we're going to design an infinity mirror hoping to create the same effect as in the original prop... fingers crossed
Stay Tuned For More! Hope everybody has a very Happy Easter! :)
man, i was going through this project (for the million-th time) and looking at all the original console stuff you had done. It is amazing to see the changes and progress you have made over such a long period of time. Its just staggering what you and the team have done. The new console is so cool; its just tight you know, all the angles and curvature to that thing is just AWESOME. I can't say it enough man, what dedication and perfection to the build!
Hi Gang,
A quick morning update. A little more forward progress.
Two new panels with satin clear
Holes drilled in the "radar" panel
Painted
Marking out the pin stripes
This pin stripe is going to be tough to mark out!
The next victim!
Lots More Coming!
Hi Gang,
A possible greeblie find? One of the many things I've been working on behind the scenes is designing greeblies (lots and lots of greeblies). One of them is the greeblie found on the door.
Daniel stopped by and took a look and in a split sec thought it might be a automobile headlight trim piece from the 70's. Makes total sense! He's a genius...
The part I'm designing
If I remember correctly... back in the 70s there were only 3 basic headlight shapes: round, square and rectangular. Looking at the rectagular opening in the middle of greeblie, where the mesh is now located, makes me think this is a great place to start.
What do you guys think? Any ideas?
