Re: My Fifth Element Multipass (build)
Knowing full well that screen caps do lie, I want to show some stuff I got tonight.
I can see the shadow around the disk, I beleive that is raised. I can also see the screw hole (that's what she said) on the rectangular part. What I"m not convinced of is that the rectangular part is raised. I just don't see a hard edge on the two borders where there should be one.
I found this one also:
where you can CLEARLY see that there's a disk on the back that is not integrated into the body. I'm totally on board with the idea that the disk is the battery case, and is removable. But if you look at the overall thickness of the pass, I don't see how there could be an additional layer in there to account for the thickness needed for the rectangular part.
Don't get me wrong, I'm not defending my kit for the sake of defending it. As many of you know, I have improved and altered the kit as I've been going along based on feedback and feasability. I'm just not seeing that rectangular thing.
But the BIGGEST bummer for me, and the thing that has continued to stump me to this day comes from this screen grab:
What the heck is that line just south of the red bar? It looks like there's a whole other layer there, over what I call the "lower arm" of the pass. But there's no other screen grabs to support this, and I cannot make sense of how that would even work.
Lastly, this picture points out a couple of weird things. First of all are the marks around the yellow dome. Two at the bottom, and very faintly one on the top. These can also be seen in the shot of the pass sitting on korben's desk. For all I know, this is from where they screwed in the screws too tightly from the battery case, and they are pushing up on the styrene. That would make total sense, and may be the case.
But what you can also kind of tell here is that the ring around the dome is NOT flat. I knew this from the start, but couldn't figure out an affordable and easy way to incorporate this into the kit, so I skipped it. it's VERY subtle, but it's there.
You can also see from this picture how the grommet appears to be painted over.
Discuss.
