Re: Hardware Build - Harry Potter Quidditch Broom for my Son
Uuggghhhh! I've got a bit of bad news, some pretty good news, and then some really great news!
First the bad news. And I really hope anyone else trying this doesn't have the same thing happen to them and can learn from my mistakes.
I originally soaked the grass so that it would be more flexible and less proned to break. Unfortunately, it ALSO causes it to swell. Putting the grass into the clamp wet and then tightening it down as tight as it would go, worked for about a week until the grass (which was evidently still wet on the inside) fully dried. I had been hanging the broom by one of the foot pegs so the varnish could fully cure. Today I walked into the office to find the grass had shrunk so much that the clamp was now loose enough for the whole bristle section to fall out, which meant the handle also then fell out. I walked in and the handle and all the bristles were on the floor and the only thing left hanging was the clamp and foot pegs.
lol
cry
SO, if you're trying this, either DON'T soak the grass first, or make sure that every day or so, you continue to tighten the clamp until it's dry.
Now for the pretty good news. I ran up to home depot and grabbed a new clamp and a 3/16" x 36" threaded rod, then I ran to hobby lobby and grabbed a new bundle of the same kind of grass.
This time, I stuffed as much grass as I possibly could, packing it in as tight as it would go until I couldn't get one more blade in.
Then I pushed the threaded rod down into and all the way through the styrofoam cone and ball. The axe handle already has a hole drilled in the head end of it (where the axe head would go) so that you can hammer a pin in and separate the two wood halves, locking the axe head in place. I hammered the threaded rod down into this hole, giving the styrofoam form a lot of extra support. I then used a dremel to cut off the extra bit of rod.
Next, I pushed the ball and cone down into the grass, fanning it out until it was in the right position and sprayed the inside with spray adhesive and then bunched the grass around and re-wrapped it with bronsed copper wire and superglued it down.
I then wedged the footpegs INSIDE the clamp this time, instead of inbetween the clamp straps and the band. This hides the bracket portion a lot better and just looks a lot cleaner. I then took a ratchet screw driver and tightened the clamp down as tight as it would possibly go.
and Finally, I drilled a small hole in the side of the clamp belt and drove a wood screw all the way down and into the axe handle inside the grass to keep it from ever sliding off again.
Needless to say, it now looks exactly the same or even better and is now a hundred times more sturdy.
and Finally for the really great news. Mike, I got the logo decals in the mail and they're absolutely PERFECT! I can't thank you enough. That was truly an awesome gesture and my little boy flipped his lid when I showed him.
What do you think?
And here's the new clamp. I just need to wait for the glue to dry and I can give it a hair cut and paint!
