Darth Brass
It seems like an MDF or lazer-cut acrylic master, then molded and used for plaster casts would be the best-quality way.
it has always been a goal of mine to have one room that almost
replicates Deckard's appartment.
But...the one thing that has kind of always been at the
back of my mind about those tiles is that they must
be a real ***** to dust and keep clean.
We made a set of these at my old work. Made the master out of foam slabs, put a light coat of drywall spakle over it to seal it, then vac formed tons. here a pic of his house we did. We did two different sizes.
http://artmodelsandprops.com/My_Homepage_Files/IMG_208.jpg
Hi Guys,
The panels that were used on Deckards apt. set , Were made of thin vacuumed formed styrene. The org. panels were .040 styrene. Other areas were fiberglass casts. If your going to make them by hand then I would make them out of MDF. Much easier to work with that plywood or plex and you can still bondo it to make the bevels.
I have a vacuum form mold to make the individual panels. I was aloud to mold one of the unused Cement panels from the house about 10 years ago.
Hope this helps,
HMS Mike
For JW and Buffy fans they were used in Angel's crypt. There were also some publicity Shots of the cast of 'Firefly' set in the real FLW Ennis-Brown house I believe.
Andy
I am going to make 3 different sized Ennis Tiles.
4", 8" and 16"
I should have the masters done sometime by Monday.
Cool thread, guys! :thumbsup
I have a vacuum-formed female mold that someone in the LA prop community sold to me many years ago for $5:
Is this one of yours, Mike? I always thought I could use it as a master to make expandable foam or plaster tiles for my own wall, but never got around to it. What's the best course of action for making durable, lightweight tiles that I could double-sided tape or glue to drywall?
I also used dimensions from it to create the following 3D model:
It's more or less identical to the SketchUp model, but mine can be exported as CNC formats like IGES and STEP (skp files can only be converted to 3D print files like STL). I just need to add draft angles to all the vertical surfaces.
If anyone is considering making tooling for a 1:1 scale tile (or any scale, for that matter), they'd be welcome to my model - PM me.
