Thanks for those links. I guess I'll have to come up with some type of filler or else bite the bullet and use something for an undersuit on the legs as well.
I'm having issues with the Helmet. I'm on my 4th one now.. The first was a straight up Pepakura using card stock and the original Sharkhead file and it was a tad small and had a crazy number of fine details. I then started using JFC's unfold and made two in cardboard. I'm working on my 3rd cardboard one now. The major reason I'm on my third is refining the scale, but I keep running into issues with a certain line in the unfold...
That crease right there never seems to be in the right spot when I'm assembling the helmet. I always end up scoring a new mark before that point. I think I might be making a mistake with the side panels, but I'm not sure.
The 3D view from behind shows a fairly flat side profile:
But when you look at the 3d view from an angle it shows a more convex shape:
I am wondering if someone can help me with this issue, possibly with some pictures of your own build. I think maybe I need to start putting more of a curve in the side panels instead of leaving them flat, but I can't be sure.
Is there a best order to assemble in? I tend to start with the top, add the side panels and then work my way down the back, but maybe I should start with the back first? Any input would be appreciated.
