Re: Underworld lycan WIP.
Hi guys, I am blown away with all your great and positive comments on my project so far. I wish to thank each and every one you for this and also for all your input, photo's that you have kindly posted, web and info links etc and also for your continued assistance. The RPF is a fantastic place for sincere and genuine help, advice, tips etc and I couldn't progress on this Lycan build without all your gracious help!!
Thanks also to Mr Fett for the email, cheers buddy they are of incredible help my friend!
Update time guys:
Spent yesterday re-working the ears as they were miles off in the look department, so I decided to bin the first attempt and start again. Firstly I cut out a basic ear pattern using everyday upholstery foam, then using my trusted hot glue gun I built up layers of glue on the foam, letting it cool down slightly before using my fingers and loads of cold water to get the ear into a recognisable shape. I did this repeatedly until I got to the desired shape I was looking for. Once I had achieved a basic ear I then trimmed them and removed the access foam from the back of the ears. A word of caution though, if attempting this, use LOADS of cold water on your fingers in the smoothing out process as hot glue makes you dance if you don't do it right as some of you may know and I found out numerous times!!! I'll rough sand the ears and add a foam edge to the ears, then latex them up ready for the hair/fur to be put onto the back of the ears and edges.
After receiving some amazing help and advice from you guys I decided to have a go at the digitgrade stilts, I managed to get the front shin supports done before deciding I had had enough for the day, I'll work on the metal support frame later in the week as I want to concentrate on the skull for a couple of days so it's ready for the teeth when they arrive.
I removed the lower jaw from the skull and started to trim and clean it up a little, adding the trusted hot glue to build up areas that were out of shape (same process to smooth out I used to make the ears) yeah it's a cheat, but a quick one! I'll then fibreglass over theses areas once I completed the re-working of the skull. I'll work on the lower jaw later today and continue to work on the skulls eye sockets as they still need a liitle more work.
Again guys thanks so much for all your invaluable assistance with my idea.
