X-34 Landspeeder Dashboard greeble identification
MrV
Everybody seems keen to ID everything these days so i am keen to ID the Dashboard greebles on Lukes ANH X-34 Landspeeder.
I have started this ID sheet which i will update as information comes in.
I saved these images down from the awesome build thread by Geek1138 (photos from Rymo). These photos are from the exhibition the Magic and the Myth that toured the globe years ago. In Australia it was here in 2008.
The green items are a positive ID. Other members have mentioned having similar parts in their "spare parts box" but not a positive ID so i have not included these as green.
Thanks for everybody's help so far.
This is what i have so far...
Interesting. One of the speeder props looked a bit different at time of filming.
(also notice 3PO's shorts are sticking out of his trouser legs again. So untidy!)
  • Like
Reactions: MrV
Haha-i know. Dont look too close at R2 either- he changes so much through the entire film. Back to front legs, coloured panels etc..
I am pretty sure they had two speeders. One built on the car frame and the other cantilevered on a long arm. Both had minor differences. Not sure if they were further modified for the pick up shots in California.
This exact topic has been covered on the FB POSW or Parts of the OT group already.
I´ll see, if I can find the link.
...Found it:
Lots of parts identified already
  • Like
Reactions: MrV
Thanks for the link. A few good leads here but still plenty to find. Update pic attached.
Would be good to hear from Cal Pierce aka MonCal as it sounds like he completed a X-34 dash build.
You forgot to add the colored plastic push button caps, which are also used on the imperial rank bars (f.e.) and the small white part in the upper left corner, that I identified as some kind of vintage plug/ connector (have those in my parts boxes, but don´t know their actual purpose)
  • Like
Reactions: MrV
Yes, lots have already been IDed, would be good to clean up post #1 for newcomers
I doubt the card is from a calculator, those edge connectors are for plugging into larger panels. The square ended gold leads match the V3 cast, Skywalker Ranch Saber and Barbican cards so could possibly from a similar manufacturer. Those cards were all straight/machine soldered instead of this hand-done board
  • Like
Reactions: MrV
