Weta Workshop Chainmail
troopermatthew
Hi!
Does anyone here own a piece of Weta workshops chain mail? If so would you be able to kindly supple the dimensions of the rings used. I am trying to replicate a set of it but without a scale its driving me insane :facepalm
Thanks!
I've seen some with 1/2" rings, not sure of the metric conversion, but this was a pvc piece.
Years ago I went to the first LOTR exhibition at Te Papa in Wellington. They didn't allow cameras to be used, but I managed to measure a small sample of the plastic mail they had on display.
It was 14mm OD, 10mm ID, with 2mm wall thickness. I used a 6" steel ruler, and got a fairly accurate measurement.
Hope this helps.
Oh, just remembered the other thing - the links were sliced from a plastic tube, so they had a square section. It will hang a bit tighter than the same dimensions made with a round section link.
I made some PVC maile for my General Kael costume a few years ago.
I used 1/2in with 1/16th inch walls. (The actual diameter of them is about 5/8ths inch) PVC that I hand cut with a pvc cutter. I would highly recommend machine cutting them though.
These measurements line up exactly with the 14mm/2mm wall measurements listed above. I'm guessing that they used the same pvc size that I did.
It's super cheap at any hardware store.
Just visited and got a tour of weta workshop yesterday unfortunately not allowed to take photos in there but the chain mail system the used is actually an injected cast ring with a clip system to fasten each ring. Apparently they originally prototyped using pipe sections but found the sectioning of each ring to be too time consuming.
The rings for the mail varied depending on there role - hobbit scale/ close up etc from 15mm diameter up to around 25mm
There was around 6 different size on display
Good point about the different sizes for scale doubles. What size would the 'human' actors wear, do you know?
Well, concidering "historically" chainmail was about 2mm thick wire, and the loops were 10mm on the inside, 14mm on the outside.
You can use 8mm too.
If it helps I went for a 10mm id and 14mm outer. When I get some put together I will perhaps put a picture up with an accurate LOTR prop for scale.
