Limited Run V3 Mag UV Stable Icy Blue or Clear Replacemnt/Upgrade Soles
WizardBTTF
These are made and ready to ship out within 2-3 business days. Very limited at the moment with about 10 pairs available. Price is $100 shipped in the US, +$10 for anywhere else. Send me a message when you're ready to pay, and I'll give you my PayPal address.
UV stable Icy blue or clear soles for V3 Mag's. The blue tint is probably more blue then the 2011, the angle you look at the shoe also has a lot to do with how blue it looks it seems. Custom available, plain colors to carbon fiber, glow in the dark ect.
Sizes US10.5-US13. However, please check measurements to make sure they will fit your size before paying.
A few things to note: The material will be softer then the original soles, which I estimate to be around 60A. These soles are softer at about 40A. The abrasion tests I have done between these and the originals were minimum. However, they will probably wear slightly faster in the long run. Harder and stronger 95A material is available on request.
Also, at any given time I might a few a imperfect (bubbles ect.) pairs on hand that I'll let go at a decent discount.
Any reason why it's only a limited run? Also, will you be doing a run in a harder material later? I'm very interested in these, but would like to have as much abrasion resistance as possible. Thanks!
Right now its a limited run because its a really niche item, and I am just not sure how long I'll have time to keep making these things. I do have a harder material on hand, its 95A hardness and stronger then the original soles. Harder materials like this will have a really slippery feel when on the shoes though (less grip). When you are working with it, it will almost feel like a soft plastic. Harder materials also initially get surface scratches from asphalt, when the softer material wont wear the same way in the beginning. They all have their own little pros and cons, but yes they can be made whenever you are ready. Thanks.
Nice :) did you tried them on V2 or HCs ?
I expect they won't fit, the sole pattern is quite different :
I imagine the biggest trouble areas would be the ones I've circled. For HC's or V2's, you might be better off contacting Cavx as he made parts to suit those versions.
WizardBTTF : I'd be interested in getting a pair in blue (next pay, in 2 weeks time) that be OK?
I have size 11 V3 will they work. Plus are they UV safe and how easy are they to do. What kind of glue do you use to put them on. I just hope I can do it.
View attachment 676869View attachment 676868
@WizardBTTF : I'd be interested in getting a pair in blue (next pay, in 2 weeks time) that be OK?
Yas, looks like this won't be good. The V3 soles looks so massive from this angle
Yes, just PM me when ready to pay. Thanks.
I don't think they will fit size 11, but they might. You will need to measure your soles and compare to my photos. I wouldn't consider removing the original soles easy, some parts are glued on very well. Once they are removed though, I find gluing the new soles on easy. I have been using Freesole adhesive.
I think they will work. I was measuring my size 11's with your pictures and they look like the exact same measurements. I am thinking about getting a set from you.....
I will accept returns while I am still trying to figure out the exact sizes. So if they don't fit buyer can ship them back for a refund. (Buyer pays return shipping though)
The only thing I don't like about sizing, is I've had shoes that have the same exact number inside them...yet another shoe the same printed size be 1/4" larger. So I am afraid some shoes are getting mislabeled.
Great photo comparison DragonGalvy.
Outriggers are much wider than the standard soles on the V2/HC.
I am really in doubt about the half sizes too. I can't see them actually making all sizes in 0.5 of a number. I think they just re-badge a 9 and call it 9.5.
Do you think these will fit right on to size 10? Anyone tried?
Sent from my SAMSUNG-SM-G935A using Tapatalk
If it helps you to better identify the size ranges the V3 factory is using, your measurements also correspond to my US13 soles. It would appear your soles will replace a very wide range, and I would suspect the factory has only two sizes for the clear parts.
The released Nike patterns have an overlay view of the proportions of the size range. The images appear to show Nike sizing has the outriggers reducing by 3% per whole size. It is fair to assume your dimensions reflect the largest size, so that should provide a base line for your size offerings.
