TO LATHE or NOT TO LATHE
Some colleges and other such institutions have places you can use equipment as long as you take a class. Maybe worth doing that to learn your way around them a bit before buying?
I worked in a milling workshop several years ago,then I left.
Then I began with lightsaber hobby,with simple tools,liek everyone.
And one day I visited them to say "hello" and the boss offered me a new job.
I accepted.
And now I can work as I want,and create some good lightsaber parts,as visible on my signature,saber custom or modifications,replicas and full custom,like my steampunk protosaber.
I'm really happy,and I know I'm a lucky cow,so I try to share with the frenchies who can't acces to milling machines,and get helpful.
I have two lathes, A Seig C4, approx 9*20 lathe for general work, and a Peatol/Taig for small parts. Also A Peatol/Taig Manual mill converted to CNC, currently being used to make a Sonic Screwdriver.
A 7*12 lathe can turn an object 7 inches in diameter and 12 inches long. There are some caveats however. You will need to support the item at both ends, and you may need to move the cutting tool from one side of the toolpost to the other. You may, however, be able to extract a little more length by removing the chuck and turning your light sabre between centres. Alternatively,break up the light sabre into shorter parts with the joints at convenient places where they will not be apparent. Finally, all lathes, no matter how small are dangerous, they can remove parts of you as easily as they remove metal. You need to read and understand all aspects of the function of the lathe and concentrate on what you are doing fully. Wear eye protection and refrain from sticking fingers anywhere the rotating parts of the lathe while they are in motion. Swarf can be as sharp as razor blades so don't be tempted to grab it. And has been said previously in this thread, the cost of the lathe is only a small fraction of the total you will spend on tooling, accessories and materials.
To 'Lathe'? Well, a lathe is a wonderful thing. But that's not what he said. He distinctly said "to blave." And, as we all know, "to blave" means "to bluff," huh? So you're probably playing cards, and he cheated......
