Unlimited Run TJack's Amazing Spiderman 2 Faceshell and Lenses Combo *Kits available* see post #529
Re: TJack's Amazing Spiderman 2 Faceshell and Lenses Combo *Kits available* see post
Based on feedback from past customers, there are 3 main "trouble spots" when trying to put this kit together. One is getting the frames shaped correctly, two is getting the lenses to sit flush against the shell, and by far the most challenging part of assembling this kit is the white mesh.
I've decided to offer up with another option that makes assembly much easier, however it does compromise the accuracy a bit. On the top is the new option and below is the current mesh.
With the new option I have attached the white vinyl (same stuff I use on most the lenses here http://www.therpf.com/f13/spiderman-lenses-amazing-raimi-comic-custom-new-lens-option-179568/) directly to the lens prior to vacuforming them. This means there are no wrinkles along the edges or the need to make small cuts as I know some have done when doing the pop bottle method.
The aluminum mesh I provide in the current kit is to help hide your eyes even more and when painted black it will help reduce glare. Most people have told me that they tend not to use the mesh anyhow. The nice thing about the vinyl is that it's black on the reverse side so it already helps reduce glare. What this also means is that you only need 1 dome per eye making the lenses sit "flatter" against the frame and therefore they will also sit more flush against the shell.
As a final option (and this has always been available), you can choose to get rubber frames instead of plastic. This takes away the need to heat and shape the frames, however it makes it harder to get a shiny black finish like the movie frames have.
If you choose to select the new option, I will also take $30 off the price of the kit since you don't require the aluminum mesh or 2nd set of domes. Again you sacrifice some accuracy but will save yourself some headaches :) Hopefully some of you will find this helpful.
A better side by side shot of the 2 lens options.
The purple frames were requested for a Spider Gwen suit - keep in mind I can make them in any colour you like :)
Oh, now I think I understand this kit. So if I put the lenses together myself its $125? But if I order the ready-to-go finished product its $175?
No, I don't currently sell finished sets, only kits. The kit is $140 USD plus shipping
Hey Tjack,
I'm looking at your shell and lenses for an Ultimate spidey I'm going to be building. Just wanting to know what size the frames on this kit are? I want to get the TASM2 custom lenses for the slightly more cartoony look with the flicks, but not sure they'll fit this shell.
Cheers,
~Andy.
Hey Tjack,
Cheers,
~Andy.
The only frames that fit this specific shell are these frames/lenses. If you want a regular shell that will fit any of my other frames/lenses, check out my other shell thread http://www.therpf.com/showthread.php?t=189312&highlight=tjack
Where may I find the picture tutorial on how to put the kit together? Thanks, T-Jack! Amazing work, my friend. - Adam
I email them to the account you sent the payment from. Let me know if you need it sent again.
Happy Birthday to me!
Any order placed by 11:59 pm today (June 14, 2015) is 15% off :)
If I were to buy one pair of tasm 2 andrew Garfield version larger lenses they would be 35$ shipping to us how many days would they take to get there and are you shipping from UK or us?
Been looking on YouTube to build TASM 2 costume for the Con in Chicago. That is where I heard about Tjack's Faceshell and lens. IMHO I think it is one of the best looking one out there. Where do I see the tutorial on how to put the kit together?
PM sent!
Hey TJack
I would have sent this through PM, but it might be helpful to others too. How's the visibility through the new mesh?
Hey TJack
visibility is great. It's the same mesh I use in my other lenses thread.
Just completed the kit, not too bad for the first go around.
Nice job man, suit looks great!
Just got my kit! Looks amazing! The quality is unbelievable!! Will be putting this together when I get some time off work!
Hey TJack! I've tried to get to you last year for Comic Con New York, but I had no luck. I'm interested in the lenses and face shell for TASM2. I'm gonna try making my costume for this CCNYC.
Made in Canada, worn in Canada! Nice kit Tjack my friend!! Thank you:D
If I get this kit, do you think you could make the lenses mesh green?
