I grabbed the closest size available in white -- not being sure of the dimensions. What size are you thinking for these?That could be a trick of the light. But, could be true. On my sliding top tin research, I could not find any on white or black with the right measurements, only silver ones. Were you able to find one?
PS: Base could be easily painted in white if that the case.
Approx mesurements are 80mmx31mmx10mm or 3 1/8" x 1 7/16" x 3/8 could be fine.I grabbed the closest size available in white -- not being sure of the dimensions. What size are you thinking for these?
I agree, they must removed it from somewhere else. It is not a simple tray or drawer.It clearly had a fitted lid, the top edges at either end are recessed. So, when the lid is fitted, it would be like a clamshell design (no hinge, obviously.) Probably the same as the frosted looking bottom piece, though probably clear. The dividers look like simple plastic stock cut and set between the rows to keep them in place.
When I saw the spark pads, the first thing I thought of was gum at the Starbucks checkout counter, lol!
This case also looks to me like it was packaging for something, rather than a dedicated storage box.
Negative, these are 3.15 x 1.34 x 0.4 -- these ones -- I like the look of the coating on the bottom half, but the edges of the lid don't look at rounded as the one on the show does. (Could be a trick of the light.)Is that a 2" long tin right?
Could be the angle, but they do seem too short or too wide. The ones I got in silver are slightly narrow, like 31mm, not 34mm. But maybe is just the angle. What did you use for the sticker? Water decals?Negative, these are 3.15 x 1.34 x 0.4 -- these ones -- I like the look of the coating on the bottom half, but the edges of the lid don't look at rounded as the one on the show does. (Could be a trick of the light.)
View attachment 1690190 View attachment 1690191
Sure thing -- not planning to do a run of these, so here's the graphic I drew up.Will you be making slide transfers or files available?![]()
A stamp is a great idea! In fact, I bet it wouldn't cost too much to get some rubber ones cut by a print-on-demand site. (One for the black and one for the blue.)I am playing around with a stamp prototype. FDM printer won't achieve a great one, due resolution, but a resin will do the job just right.
Yeah, will print a prototype in flexible material like TPU and will let you know.A stamp is a great idea! In fact, I bet it wouldn't cost too much to get some rubber ones cut by a print-on-demand site. (One for the black and one for the blue.)
