You make a three part mold. One part is one face and the rim. Second mold is the other face. Their part is a section of the rim which also acts as the pour hole. Once you pour in the resin you plug it up and that creats the last part of the rim plus trims the piece out. Note: you must put this into a pressure chamber while the resin is curing and pour the right amount into the mold with just a small amount of flash squeezeing out the sides. Pretty easy to do but molding is tricky.
Holpe that helps
rick
