Spandex costumers- need dance belt reccommendations
Mados
I've tried the capezio 26 in two sizes, going to have to move up to an XL. It fits fine around the waist, but the "compression" factor is getting to me. As well as the thong aspect. Any of you guys use anything that you think is comfortable? I'm a boxers kind of guy.:lol
Do the ones with a full seat have visible seam lines? I'm going to be using this with a Spidey suit.
you have to rememeber that dance belts are made for dancers who are generally much smaller in stature than us guys! So, that means if u are a normal body guy buy the biggest one they have. They are supposed to be tight. Yes, the full seat ones will show in a Spidey suit, u must wear thong style. The whole idea of these is compression and in a spandex suit that is a must!
Thanks man. I guess I'll just have to get used to the string then.
you should also check the few styles they have. There are these 2:
this is one with a one piece all around spandex type. It has the wider of the 2 types back, but is also cut more brief:
This one has a bit more padding, lined in cotten and has a narrower back.
