Limited Run RUN CLOSED * DL-44 ESB Blaster Machined Parts Set * RUN CLOSED
Re: DL-44 ESB Blaster Active Project Machined Parts Set $100
There were TWO live fire ESB blasters... Han and Luke... and neither had pistons.
Thanks for the piston info Scott, that made my decision easier. It looks like there is something over the trigger on that side as on the Luke blaster, have any idea what it may be?
Maybe I missed the info about these...who will we have to order the brass hex-bolts from? they will be offered in two sizes, correct?
Still thinking about ordering a brass M19, even if I have enough real scopes to cover all builds...when is the deadline for the cast scopes?
Markus
Markus I forget, which blaster has the different sized screws?
I think it's one of those little circular kit parts with a LOT of glue on it.
Re: DL-44 ESB Blaster Machined Parts Set $100 JUNE 30 CUTOFF
This list will close on June 30th.
This only applies to the "Machined Parts"
I will order 10 extra Kits (6 Bespin / 4 Hoth) and have 8 available for sale but the price will be $125 for a set of parts and you will not have the option to select the exact parts you want.
Quick question(s)..
Luke's m19 has a notch, correct me if I'm wrong?
Also, does his scope use the regular or larger bolts?
Yes Luke's Scope has the notch as does the Hoth, Han's Bespin has the full circle
left to right Luke, Hoth, Han Bespin
looks like Lukes Scope has the large bolt at the front but I'm not 100% sure about this detail (I'm sure someone will chime in :))
With apologies for being a total blaster newbie: what are we looking at in those three images? What is the "notch" you're discussing? Where are the large/small bolts?
Certain versions have a notch cut into the bottom portion of the circle on the side of the m19 scope.
The bolts we are referring to are the screws on the bottom connecting it to the mount.
Hope this helps!
Hope this helps!
It does, thanks! I can't make out Han's Bespin bolts. Is there a consensus on sizes there?
wow this really helps me out, i really appreciate posting it! you see i never knew about hans being a full circle? im going to go for the han live fire like seen here
i dont know what bolts han has, so i figure i will order 1 normal set of bolts and 1 large bolt encase somewhere down the road i can get a clearer shot proving it he has a large bolt
also thanks think jedi, payment sent for reserve! ;)
Will a real M19 fit and can I order just the bolts?
Email sent for reserving a scope. Arrangements made so that I will pay on Friday.
Thanks for doing this project, Boba Debt, and thanks for being so hospitable to a newbie! Looking forward to getting these awesome parts! Payment sent!
Those plaques look great, I'd take one Luke version!
Invoice paid :thumbsup
