Limited Run RUN CLOSED * DL-44 ESB Blaster Machined Parts Set * RUN CLOSED
Re: DL-44 ESB Blaster Active Project
Hmmm, what to order? decisions, decisions :lol
I'm definitely building the Hoth blaster, just need to decide if I also want to upgrade either my Han Bespin or Luke with some new parts while I'm at it,
will your flash hiders just fit straight on to a Denix barrel (with the sight removed) or will some filing be required?
I had to file down my Han Bespin barrel a fair bit to fit through its current evolution props flash hider so it may be too narrow now to just swap over
guess I'll sleep on it tonight & email my order tomorrow :)
My flash hider design uses 2 different diameter bores so it really only has to fit in one spot, most of the time you can just twist it to make it work.
In some cases you might have to add a little black tape to make the barrel diameter large but those cases are rare.
I got a bad feeling about this! My wife kills me. Have to finish the ANH for first. I will return. oO
email sent.
Bespin flash hider
Bespin Luke scope bracket
Bespin scope bracket disk
Bespin scope bracket spacer
Hoth flash hider – no knurling
Hoth scope bracket
Hoth scope bracket spacer
ESB accurized Mauser drilled for Bespin
boba debt, I'm sorry i sent you a email this morning with my order. under the flash i put "hoth with 2 knurling". is it too late to change it to a bespin flash with 3 knurling? I'm so sorry for being a PITA. i feel bad :(
oh my god your going to kill me, i screwed up royally... the thread messed me up completely between luke and han, both and bespin. i now think i understand
I'm trying to replicate this dl-44 from this picture
http://www.therpf.com/attachment.php?attachmentid=413118&d=1418005774
thats means i would need
Bespin flash hider ( 3 knurled rings )
HAN scope mount
bespin scope bracket disk
beeps bracket spacer
boba can you just delete my first email and i send another to make it easier for you? i won't send another email until you have confirmed you deleted my first one, I'm so sorry for this confusing I'm a idiot
No worries, just send me a new email
HAN scope mount
email sent. parts requested:
1 Hoth-2 flash hider
1 Hoth scope bracket
1 Hoth Scope bracket disc
1 Hoth scope bracket spacer
Woot!
This all looks amazing. Great work!
Email sent.
-John
Email sent for
(1) Bespin Disk
Wish I could buy more but it's just not in the budget. And I've been wanting a good knurled disk for my Denix, so this is great.
Thanks - Matt
Can't wait to finally replace the resin bracket and scope on my Luke blaster!
Email sent. Guessing that the parts plus ESB accurized Mauser is roughly 2/3 of the cost. Looking forward to getting the rest of them!
(though surely my wallet and girlfriend are less excited than I am)
Email Sent
after a couple of days of procrastinating I ended up ordering a full Hoth & Bespin :lol
It was always my plan to completely re-build the Hoth Blaster but then I decided I needed a new flash hider & Scope mount for my Han Bespin & a new scope mount knob for my Luke,
my only concern is that my Han Bespin currently has a Blastech scope mount which has the mount knob a little lower on the Mauser (than my Luke) just hope I can easily swap for the new one & it still sit in the right place
so I guess I'll be needing a couple of scopes & maybe some wooden grips if they're on offer this time round :)
I usually use a nut on the inside of the Mauser to hold the threaded rod for the scope mount in place (I can't tap), will the threaded rod & a nut for the scope mount be included? Or if not can you please let us know the thread size for the mount knob so I can pick some up ;)
The Hoth Blaster Scope disk uses 3 bolts/nuts to hold it in place and they will be included
Email Sent
^I think I like the second one the best.. the first is also good though
