Boba Debt
Re: Replicating a 1/10 Scale Iron Man Hall of Armor Display
If you look straight on at the display you will not see the exposed sides but in my case it’s going to be the first thing you see.
As I said, I’m going to have 2 banks of 4-5 bays that are perpendicular to each other
The first thing you will see is the unfinished side.
Here is a picture of where mine will sit:
But forgetting all of that, I’m amazed that Diamond got away with this. I can understand variations in the sculpt and production paint jobs that are not as nice as the hand painted prototypes but when a piece is completely different that should be a problem that gets corrected.
Even the images on the packaging show solid sides.
Actually I think the Revoltech Figures will look fine in the Marvel Select Bases.
The 7” Marvel Select Figures look toooo big for their own HOA display base, especially since the head sits above the top of the wall.
However, a 6” figure will probably look right. I will know soon enough since I have 2 more bases and most of the Revoltech figures coming
ANYWAY
I spent about an hour in my shop cutting the left and right side so they would be thinner and then I hand lapped them until they were flat enough to glue together which created a wall that will work for the left, right or center wall of a bay unit.
I compared these walls to the real thing and the distance above and below the light is smaller then the Marvel Select Walls. I also think this display might be about 3/4” too tall for a 6” figure.
To fix both of these issues I will cut about 1/4” off the top edge and a 1/2” off the bottom
I know there are still exposed holes on the outside but I’ll cover them up with some model parts and it should look fine.
I was going to have this wall cast in resin or 3D printed but it might be cheaper to just repeat this process 10 more times
You're not going to see that part anyways?
I have a feeling you'll be better off making a Hall of Armor from scratch. You might be disappointed with the Marvel Select bases now, but you're going to be even more disappointed when you get the Revoltech figures. The Revoltech's are, as you said, 6 inches tall, which makes them 1/12 scale, so the Marvel Select bases are probably going to end up looking too big. I recommend seeing what you can mock up with cardboard, styrene, and insulation foam before making any further investments.
ANYWAY
